Introduction: Pedometer Part 1: 128x32 Monochrome Screen and Arduino
This is a basic tutorial teaching one how to use an OLED screen with their Arduino. I am using a 128x32 screen but you can also use a different resolution oled screen and change the resolution/coordinates as required.
In this part I will show you how to display a pixel, words, and numbers. In the next part I will show you how to use the ADXL335. Then I will move from and Arduino UNO to Pro Micro just for portability and also go over how to make a cheap charger for it.
Step 1: Stuff Required
1)Arduino (I am using an UNO)
2)128x32 oled screen
3)4x Male to Female Jumper Cables (You can also use Male to Male jumper cables and a breadboard)
Step 2: Connections
Display=>Arduino
VCC =>5v
GND=>GND
SCL=>A5
SDA=>A4
Step 3: Libraries
1)Adafruit GFX
2)Adafruit SSD1306
Step 4: Code
My display is monochrome so it only displays in blue. In the code I use WHITE because that is the current code.
In #define OLED_ADDR 0x3C you have to paste the I2C address instead of 0x3c of your display.You can find it by using an I2C scanner code which can be found easily.
Step 5: Demo and End
I hope you liked the tutorial and thanks.
