Introduction: OV7670 Without FIFO Very Simple Framecapture With Arduino, Black/white
This instructable is for all the people struggling to just take a picture/grab a frame with their OV7670 without FIFO. I made this purely as an introduction. I do not yet posses the necessary coding skills to make a really great description. This was made to hopefully save some people a lot of the hours I used researching the OV7670 wanting to see if it worked.
All the coding provided is copied from these links:
http://forum.arduino.cc/index.php?topic=159557.0 (From a really cool guy but obviously not a fan of the arduino IDE or windows)
http://embeddedprogrammer.blogspot.dk/2012/07/hack... (Provides a lot of usefull information for understanding how the OV7670 works)
http://privateblog.info/arduino-uno-i-kamera-ov767... (is in russian, but with google translate you can actually extract some useful information)
Other useful documents are captured in the rar file.
Step 1: Identify Your Camera
This might be a little redundant but before you get down to the nitty-gritty make sure that the camera you bought is the one without FIFO. I bought mine from http://www.dx.com/p/jtron-ov7670-300kp-vga-camera-.... If your pins mention fifo or you do not have 18 pins for exits this is not the tutorial for you! Btw, if you are thinking about buying the OV7670 and you don't do coding let me save you some time. Spend a more little money and go for one that is better supported by the community for non-coders.
Step 2: Connecting the Pieces
The OV7670 is not rated for voltages above 3.0v. Hence the voltage divider for the XCLK. Futhermore the OV7670 does not provide higher voltages than 3.0 which is a little low to be sure the arduino reads the input as high (it starts at 3.0v). Therefore we connect pull-up resistors.
Step 3: Upload Sketch to Arduino
The sketch is borrowed from this link:
https://github.com/ComputerNerd/ov7670-no-ram-ardu...
and put together in the ino file I uploaded (From_Computernerd).
Just insert the ino file in the Arduino IDE and upload it. Don't mind that it does not recognize some libraries in the beginning of the file. If it bothers you, comment the whole line out with //
Step 4: Different Option to "grab" Picture
If you only care about making the OV7670 work, proceed to the next step.
This is just to inform people of some of the different options to retrieve the pictures from the Arduino. I tried using the framegrabber from ComputerNerd:
https://github.com/ComputerNerd/simpleFrameGrabber
It seems to be written in UNIX/Linux. Hence I tried downloading the MinGW, which should be able to run the code. After adding several packages in MinGW I had to stop because MinGW does not contain the termios.h library which is used in the code.
Another option to run GNU in windows is Cygwin. In Cygwin you also install packages with different libraries. I tried running the code installing new packages whenever Cygwin told me a library was missing. In the end I was able to compile an exe file but it wouldn't run because allegedly cygjpeg-8.dll and cygSDL-1-2-0.dll was missing even though I had installed both packages.
Finally abandoning all hope of running the "original" framegrabber I found a russian website where a guy had made his own framegrabber in java instead.
Step 5: 1. Half.
-Create a new folder on your c drive called out, like c:\out. This is where the pictures will end up.
-Download and install java SDK 32bit (don't install the 64 bit version even if your system is 64 bit) I've tested this with version 8u74.(I've included it as a rar-file because it wouldn't let me upload the exe-file)
-Find out what USB port your Arduino is connected to, something like COM3 or COM4. Check pictures to understand how.
-Depending on what port number your Arduino is connected to, download the corresponding file: COM1 = com_1.rar etc.
Step 6: 2. Half.
-Go to the "bin" folder, where you installed the Java SDK. By default it should be C:\Program Files (x86)\Java\jdk1.8.0_74\bin.
-Unpack your corresponding com_#.rar files in the directory. Check picture for help. (it might ask for adm. permission)
-Download and extract the Extra.rar file. The "win32com.dll" is placed in the "...\jdk1.8.0_74\jre\bin" direktory.
the "comm.jar" in "...\jdk1.8.0_74\jre\lib\ext" and the "javax.comm.properties" in the "...\jdk1.8.0_74\jre\lib" directory.
-Open cmd
-Open the folder wherein the code is (mine is): cd C:\Program Files (x86)\Java\jdk1.8.0_74\bin
Write: java code.SimpleRead
Enjoy! (It isn't much but at least you got it working)
Step 7: Troubleshooting and Pictures
-If your cmd does not "FIND" images try switching the USB of the arduino from a USB2.0 to a USB3.0 (blue socket) or vice versa.
-If your cmd does not "FIND" images or if you recieve SCRAMBLED pictures, you need to edit the ino file. Edit the line: wrReg(0x11, 12);
try changng the 12 to 11 or 10 or 9 or 13. Upload it to the arduino and run the cmd code again.
Good luck!
27 People Made This Project!
- v.esmaeilzadeh made it!
- igor.rueda.salazar made it!
- uva_skt4041 made it!
- MECHAsajjad made it!
- ocean721ce made it!
- PascalE5 made it!
- ProbudhaB made it!
- PrajwithU made it!
- MahmoudE116 made it!
See 18 More
175 Comments
4 years ago
how to connect arduino mega2560 with ov7670 non fifo module? bro
Reply 9 months ago
9 months ago
I am Struggling in "Error: couldn't find the main load class" in command prompt
please help
3 years ago
Hi .... I am Struggling in "Error: couldn't find the main load class" in command prompt
please help.. its urgent
3 years ago
my arduino mega is on COM8. so nothing happen because we can't use COM1,2,3,4 and 5 for COM8, What can i do? please help me, thank.
4 years ago
Hi, very nice, I am using Arduino MEGA what changes should be done, please help me I am an Engineering student.
Reply 3 years ago
hi did you get it?
Question 3 years ago on Step 2
Hi, i have to use the 2560 mega board instead of arduino uno, is then the fifo module compulsory? if not, can you please help me with the pin diagram?
3 years ago
I need suggestion about the following points:
1. How can I print the camera captured data into serial monitor?
2. What should be the necessary setup required for 64 bit computer?
3. Will you kindly provide me the class file based on 64 bit?
If anyone help me, then I will highly obliged.
3 years ago
Hi kepp
Thanks for such a detailed tutorial. I’m using arduino bluno by dfrobot a d I’m stuck at “looking for image”. I have checked connections many times and followed each step. Can arduino board be reason?
Tip 3 years ago
Reply Upvote
if you want OV7670
https://www.youtube.com/watch?v=y2myh6Mptt0
I got new video about OV7670,, and it's work
Question 4 years ago on Step 6
Plz sir, i really must know. Is there any way to find the temperature using the ov 7670? Also my images appear like this. is this is a problem with cam? or code?
Hello, I tryed to change the resolution, but i wasn't successful. Can anyone tell me how to change resolution to the lowest value? 40x30 would be just fine. Thx
4 years ago
I have bouth a OV7670 camera module.
I have installed the code and ran it again and it is still "looking for image". What can I do?
I have tried the connections to SIOC-A4/A5 or SIOD to A5/A4 and no connection to HREF. I have been trying it for last 3 weeks but in vain. Do help me out to complete the module...
Reply 4 years ago
Have you solved it? I have the same problem... always "Looking for image"
Reply 4 years ago
Hello, i also have the same problem.
The cmd prompt stops at "Looking for image".
How do i get past this?
Thanks
Reply 4 years ago
no idea
5 years ago
I meet the same problem too
the cmd is stop in "Looking for image"
I follow the steps 100% and I download your JDK version as well
and my ov7670 is without FIFO too
My arduino upload files in port4 and I use your port4 files too"
What can I do?
this project is important to me
plz help me!!!
Reply 4 years ago
Hello, I'm presently experiencing the same issue.
My cmd prompt stops at "Looking for image".
i followed the steps as detailed in the report...did the SIOD/SIOC swap with A4/A5 pins, disconnected HREF. Still no improvement.
Please, i need your help
Thanks.
Reply 5 years ago
I have the same problem as you and how can you fix it?I have done an important project as you, can you please help me?
