Introduction: Oatmeal Chocolate Chip Bars
One of my favorite desserts, oatmeal chocolate chip cookie bars have long been a part of my baking repertoire. A blend of two classic flavors, oatmeal and chocolate, creates what I would describe as one of the best flavor combinations out there. Most people will be more familiar with oatmeal chocolate chip cookies, but this is essentially the same thing in the form of a bar which I find preferable for no particular reason. What follows is the simple recipe my mother and I have used for years and are now sharing with you!
Step 1: Safety and Some Baking Materials
Safety Reminders:
- Wash your hands after handling eggs to reduce chance of getting salmonella
- Naturally, ovens get VERY hot, so wear oven mittens or another equivalent when putting things in and taking things out of the oven.
- To reduce contamination of your ingredients, do NOT return excess ingredients back into their original packaging
Recommended Cooking Materials:
- 13” x 9” Pan
- Large Mixing Bowl
- Electric Mixer
- ¼, ½, ¾ Cup Measuring Cups
- Cooking Spatula
- 1 Teaspoon Scoop
- 1 Normal Bowl
- 1 Fork
Step 2: Ingredients
1 ¼ cupBUTTER or margarine, softened (2 ½ sticks of BUTTER)
¾ cup firmly packed BROWN SUGAR
½ cup granulated SUGAR
1EGG
1 teaspoonVANILLA
1 ½ cupsFLOUR
1 teaspoon BAKING SODA
3 cups rolled OATS, quick or old-fashioned
1 cup CHOCOLATE CHIPS milk chocolate or semi-sweet
*Brands shown above are not required, just the ones I happened to have on hand.
Step 3: Some Simple Prep-work
Set your BUTTER on the counter for a few minutes so it softens as it gets closer to room temperature.
Pre-heat your oven to 375 degrees Fahrenheit
Grease your 13” x 9” pan with CANOLA OIL (or whatever you usually grease your pans with)
Step 4: Mixing the Butter and Sugars
Combine the compacted ¾ cup of BROWN SUGAR, ½ cup of SUGAR, and 1 ¼ cup of BUTTER in the mixing bowl and mix them until the mixture becomes almost creamy.
I recommend using your spatula to scrape a the mixture into the center of the bowl. This helps create a more even mixture of ingredients.
Step 5: Adding the Eggs and Vanilla
Add the EGG and 1 teaspoon of VANILLA to the mixing bowl and mix everything with your mixer until everything is mixed.
Step 6: Flour and Baking Soda
In a SEPARATE BOWL, mix the 1 ½ cups of FLOUR and 1 teaspoon of BAKING SODA with a fork.
(This will help more evenly distribute the baking soda throughout the overall mixture.)
Once these two ingredients are well mixed, add them to the main mixing bowl and use your mixer to mix the ingredients again.
Step 7: Adding the Oats
Add 3 cups of OATS into the mixture and mix them with your mixer.
Step 8: Chocolate Chips!
Add 1 cup of CHOCOLATE CHIPS and mix them into the mixture.
Step 9: Into the Pan...
Dump the mixture into your greased pan.
Using your spatula, spread the mix as evenly as you can across the pan,
making sure you get some into the corners.
Step 10: And Into the Oven!
Place in the pre-heated over for about 22 minutes, adding time as necessary.
The cookie bars will be done when the edges start to brown and the center is a nice golden brown.
Step 11: Time to Clean Up
While waiting for the cookie bars to finish baking, I suggest going ahead and cleaning up the prep area.
Wipe down the counters, put everything back in its place, and wash any dishes used.
Step 12: Bon Appetit!
When the edges are starting to turn brown and the center is a little lighter than the edges, go ahead and carefully remove the pan from the oven using oven mittens.
I recommend waiting about 5 to 10 minutes to cut them so they have a chance to cool down.
When cutting, I generally make a 4 x 6 grid and I use a plastic knife so I don’t scratch my pan too much.
I also find it easiest to serve straight from the pan once it has cooled off and you are ready to serve.
3 Comments
5 years ago
Homemade bars are always better than the ones that you buy in a store.
Reply 5 years ago
so true...! wanna try this :)
Reply 5 years ago
Agreed
