Oil Projector Machine
Intro: Oil Projector Machine
I'm not the best in English, apologize if I fail in my speech.
what you need:
- 4x 15cm circled acrylic glass (3 mm thick, other sizes will probably also work)
- Acryl glue
- wood ( I took laminate)
- screw and plate
- Lens system or somthing like a lens to projekt (i took an old slide projector)
- Paraffin water and printer ink
- leather for covering the edges
- 10W LED + cooler and 5-9V trafo
- 1 rpm motor (220V)
- threaded rod
- switches
And last...strong nerves!!
what you need:
- Acryl glue
- screw and plate
- threaded rod
- switches
STEP 1: Glue the Two Acrylic Circles
Put both discs together, glue them and leave about a 1 mm gap between. I used a piece of plastic.
Leave a gap to take in liquid.
STEP 2: Select Correct Fluids
I have tried a lot, it was best with paraffin and colored water.
Best 3/4 oil and 1/4 colored water.
you can mix any color you want.
- Close the opening with a soldering iron.
!!!this is done twice and both mixtures are welded together!!! (Picture in step 5)
STEP 3: Lens Selection
Now turn the LED on and put the lens of the slide projector and calibrate the objektiv, that you get a good picture on the wall.
You can also use only one lens but I've simply taken the two originals.
STEP 4: Mounting
Next step: mounting the components on a fixed plate. (e.g. on a laminate plate)
I have welded a screw on the middle of the disc, to mount it on the engine.
STEP 5: Test
I have only choose a 8V transformer for the LED, it is not so bright like 12V but that way you don't need a fan to cool.
STEP 6: Case
STEP 7: Completion
I wanted to make it without a fan but I safely install a fan, because some heat formed by the engine and the led.
