Introduction: Make Your Arduino Project Wireless in Minutes, With the Wireless Inventors Shield
The inventors shield uses a wireless pipe, which is a special wireless RF module that allows you to easily and reliably, send and receive error-free wireless data between two or more Arduino boards.
It's Long Range – distances up to 500 feet (150 meter).
It’s Error Free – built-in forward error correction and data recovery, you only ever receive cleaned and CRC verified data.
It’s Simple To Use – anything you input, is wirelessly transmitted, then cleanly outputted for you on the other end.
It’s Immune To Noise – your data inside the wireless pipe is protected from the elements outside such as interferences like WiFi, Bluetooth, Zigbee, cordless phones, cellular phones, all types of servo and motor noise, etc. All things which typically stop your wireless project in its tracks, are no longer an issue.
How is this different from other wireless RF Shields for Arduino?
Our Wireless Inventors Shield is complete. No additional RF module to purchase which makes it about half the price of other wireless Shields.
This Shield will work with both Arduino and Arduino clones.
It has a substantial range improvement over Zigbee, Xbee, Bluetooth and WiFi.
We did range testing the same way you would do range testing, in a real world, live application. The Google maps below illustrate our wireless RF Shields results against Zigbee (the best competitor tested):
Wireless Inventors Shield for Arduino range test result (no configuration needed).
Zigbee radio module test - best configuration. In comparison our Shield had nearly 3x more range.
Zigbee radio module test - worst configuration. In comparison our Shield had over 20x more range.
If the above Zigbee radio modules were tested in an open field, without being near any WiFi or other types of interference, they too would perform the same as our Wireless Shield in either configuration. However this is simply unrealistic; since typical usage is in heavily populated WiFi areas. Unless your radio device is immune to WiFi interference, it's range is going to be drastically reduced.
Our Wireless Shield had no range reduction. It is immune to all WiFi and other 2.4 GHz noise, therefore performing consistently and reliably in typical usage scenarios.
Features:
• It's plug & play.
• No settings.
• No configurations.
• No long manuals to read.
• No data sheets to understand.
• No MAC addresses to deal with.
• No need to find the right channel.
• No complex functions to call.
• No escape command sequences to learn.
• No need to know anything about wireless at all.
• 2.4 GHz worldwide compliant.
• LEDs for TX and RX
• Built-in antenna.
• Compliant and approved: FCC, IC, CE, ETSI, RoHS
How do I use it?
Just plug it onto your Arduino Uno (or clone).
Here is all the code you need to know to send and receive wireless data:
Serial.begin (9600);
Serial.write (SendByte);
ReceivedByte = Serial.read();
That’s it. Yes, it really is just that simple!
What can I do with it?
You can make any Arduino project wireless instantly. This is a clean wireless-pipe, any bytes you put in one end, you get out the other. Since there is no protocol to adhere to, you are truly unrestricted.
What else can I do with it?
You can use a USB dongle, which allows the Arduino to wirelessly communicate with any computer or the web.
You can use multi-button keyfobs to add very cool remote control capability to your Arduino projects.
You can also use your Arduino Wireless Shield to communicate with a stand-alone breadboarding RF module that can plug into any standard solderless breadboard, giving you full range of flexibility with your project.
Can it work in groups and multi-point networks?
Yes! You are only limited by your creativity and your imagination.
Can it also be used in classroom environment?
Yes! You can have multiple PRIVATE wireless pipes running independently.
• Does the Shield run on 3.3V or 5V?
The shield UART input and output is at 5V. The on-board radio uses the 3.3V supply from the Arduino board. Also the 5V supply is used for solid 5V UART output. There are internal logic level shifters, which are ICs that produce solid logic levels so there is no issue with slew rates, ringing or having too little drive current.
The UART output uses a 5V logic buffer so you have a full 5V swing.
The UART input uses a 3.3V logic buffer with a 5V tolerant input.
They are both internally resistively pulled up to maintain a proper steady state levels and keep the UART quiet when not being driven from either side so there is no noise or chatter of any kind, and no worry for false triggering which prevents glitches which might otherwise allow a UART start bit to sneak a byte through. Basically its a clean bi-directional UART driver circuit.
• Can I use it with a software UART instead of the hardware UART?
Yes. There is an on-board slide-switch, that allows you to switch between the two hardware UART pins or pin 12 and 13 on the shield which allows you the option to configure a software UART there and free up the hardware UART for other uses.
Here is a page reference from Arduino on the software UART usage option:
http://www.arduino.cc/en/Reference/SoftwareSerial
Also see my FAQ about using the Arduino Mega.
• Can I use any of the 4 harware UARTs on the Arduino MEGA?
Yes. All you need to do is slide the Hardware / Software UART switch to the Software position on our Wireless Shield and that will place the UART TXD and RXD pins on pin 12 and 13 which are GPIO, then simply don't use those two pins (the Mega has so many anyway). Instead jumper from those two pins over to any of the other three hardware UARTs on the Arduino Mega.
• Can I form my own simple private network of devices?
Yes you can. When you use any of these devices, they are all fully open to each other, meaning any device that transmits, all the other devices it will hear it. However, you have the options to flip the switch on the Shield that tells it to go to a private wireless-pipe mode, then simply by pressing the Learn button on the Shield you can teach up to 60 Shields, Keyfobs, stand alone breadboardsing RF Modules or USB Dongles to each other and form mini-networks which will ignore devices outside of their network, so you will not be bothered by others around you.
www.OpenSourceRF.com
25 Comments
4 years ago
I will try this with my boys this weekend. Great!
4 years ago
its very expensive, i tried to buy 2 it cost me 70Euro !!!
6 years ago on Introduction
I take it you are out of business?
a shame - it was a great idea :-(
Reply 5 years ago
doesn't seem to be out of business if you visit opensourcerf.com
http://www.rfdigital.com/product/rfd21815-eval-board-for-rfd21733/index.html
6 years ago
Hi, I am very new to this and am attempting to make a scoreboard for our local Aust Football club. I have things working but would like to have control for a distance so wireless. All I need to do is transmit 2 scores for each team to the scoreboard that has an arduiuo to control the scoreboard. The control box that is transmitting also has an arduino. It seems that this should be possible with this shield. Can you confirm?
8 years ago on Introduction
hi there,, i'm really new in this and i want to make a project for my class,, i already have an arduino uno and i used it a little bit. but i wanna do is a car that can be controled by internet or a lan, using my computer.. i saw some instructables here, but now i found your post and this product looks very good, is this a shield that i put whit my arduino?, like zigbee,.. if that the case, please, what quantity of shield do i need? and what else do i need?? thanks ...
I used Bluetooth to control an rc car between my pc and car using an Xbox controller
hi, am doing my project in wireless, through ardunio could in transfer an 5v supply from supply board to the stator of an servo motor to contorl the robo? through this can i fully control the servo moter input and output wires through wireless? please send me an suggestion
U will probably need either relays or motor controller...
can my wireless camera be able to send live video on receiving end using this shield
hi , i'm in a competition that i have to control my robot wireless ....in my past robot competition i use arduino uno to control it but now i didn't know how could i control my robot wireless ....... can that wireless inventor shield do what i want ??? and how could it will be connected with my remote control ??
hi. i am making a voice recognition rc car. So, would this be helpful. If so where can i buy it ?
Hi there. Does this shield use full duplex communication?
Hello. It does not. Nothing wireless other then a cell phone does. It does have hardware full duplex UART. But over the air it's simplex.
Hello, thank you for your post. Here is where you can go to get the Shield:
http://opensourcerf.com/rfd21815-wireless-inventors-shield-for-arduino.html
Note this is not a lan Shield, what this shield is for is to provide a wireless pipe for sending simple bytes in an out, then you can also get the USB Dongle we have on our website to get the bytes into and out of your PC, then you will need to use a comm port on your PC to easily send and receive the bytes. However the connection to the LAN / Internet is something you need to do on your own with your PC.
now this looks good :)
what would the cos be? also the breadboard modules can be used together sans the main shield? (i tend to use minis and pro arduinos)
Hi Bongmaster,
The cost is $30 for the Shield and you can get them now at this link:
http://www.kickstarter.com/projects/1608192864/open-source-wireless-inventors-shield-for-arduino?ref=live
The breadboarding modules are $20 each. Yes, you can use one breadboarding module and the Shield together. Keyfobs, USB, all of that can be used together or individually.
If you have any more questions, we're happy to answer.
i meant can you use 2 breadboard modules together only.
i'm wondering if they would be a suitable application for use in RC development
if u can challenge xbee with both price and range then u'll be on to a winner ;)
Hi Bongmaster, Yes, you can use two breadboarding modules together, without the use of a Shield or any other parts. Yes, an RC application is great, they are small, low power and light weight.
The breadboarding modules are $20 each, so they are the same price as the most lowest cost Xbee out there, however range wise they might be a bit more compatible with the more expensive Xbee parts that have higher power so they can go loner distances. So we might have a winner on both counts, you would need to try to confirm that yourself of course. :)
We're always here to help.
well i may be interested in a pair of the breadboard modules, would be good to see the things in use. a 2 way RC system is what i have in mind, something like sending gps coords, and even giving them.
yea xbee power/range to price ration has always been put off
your module sounds like it has the range, as long as its stable for the job. and the price seems good :)
