Optical Mouse Cursor Movement Problem
Intro: Optical Mouse Cursor Movement Problem
An optical mouse's "optical surface sensor" must be kept a certain distance from the table for it to function properly.
A new optical mouse's plastic base is designed to keep the "optical sensor" an optimum distance from the table.
After many hours of moving the mouse about on a table, the mouse's plastic base slowly wears away causing the optical sensor to become to close to the table's surface which then causes the sensor to malfunction (jittery, slow unresponsiveness).
The simplest way to correct this problem is to is to rebuild the base's surface. This is done by sticking on a few layers of sticky labels onto the bottom of the mouse so as to raise the optical sensor up from the table to the distance it was when the mouse was new.
As time goes by and when the labels eventually wear out from use you can just replace them.
5 Comments
tomhart1 4 years ago
HussamK1 6 years ago
Did NOT Work
goldenshuttle 10 years ago
good tip....btw if anyone see s an old rolling ball mouse sold for 1$, buy it bcoz inside there are at least 2 optical position sensors, few switches which is cheaperthan to buy these parts frm ebay...
hobhob 8 years ago
Good to know, thanks!
hobhob 8 years ago
Saved my little mouse (nameed Iky ze blue)
