Introduction: Optimizing Batch Codes II
Hello everyone, I haven posted a tutorial in a while so here is a sequel to optimizing batch codes. The original can be found here!
I also recommend A full screen matrix batch code here
Thank you everyone for over 50,000 views!
Step 1: & Again
The & command allows you to run multiple commands on one line of code.
For example
echo hello & goto lable
This can be useful for not using lots of lines in a long code.
Something I found out recently is that some commands dont require a space; however, I wouldn't recommend the following method because it impedes on readability
Echo hello&goto lable
This will have the same output.
Step 2: Set Doesn't Need Spaces
Set /p is a very useful allowing users to input and set /a a counterpart that can preform basic arithmatic (+-/*).
Set /p var=
Can be shortened to
Set /pvar=
Again I don't recommend using this often but to save a byte here and there it works.
Step 3: Counting From Zero
Occasionally seting a variable to count something is required for example if I want to keep track of how many times a batch file is run and save the number in a text file I can.
Here is a basic counter
set count=0
set/acount+=1
Notice I removed the space in set /a
The first line isn't necessary because it automatically starts at zero.
Step 4: Redirection
In batch it is possible to send text or a variable to a text file. A space isn't needed before the ">" and it's still legible.
@Echo This is some Text > FileName.txt
:no space
@Echo Some more text>FileName.txt
:I'm not using goto so this lable should work as a comment too.
Step 5: @echo Off
Every batch script you see will probably start with that line but if it's short it might not have to.
@echo off is 9 bytes so if you have less than 9 lines you can use "@" to suppress it
@echo hello world
@ pause
Or even shorter
@echo hello world&pause
Step 6: Final Note
Thanks everyone I hope these helped you. Not everything in the prequel was mentioned so I recommend checking it out.
