Oscilloscope Clock on a Raspberry Pi Pico
Intro: Oscilloscope Clock on a Raspberry Pi Pico
Overview:
Somehow I've built up a collection of old oscilloscopes. They are useful when I'm building or fixing stuff, but the rest of the time, they just sit on the shelf doing nothing. So what I needed was an unusual use for them.
This Instructable is a proof of concept, so only assembled on a solder-less breadboard, and is intended to see if I could get the scopes to display something a bit more interesting than just the usual wobbly lines.
Features:
- Two independent 8-bit Digital to Analog (DAC) channels using R-2R networks.
- Oscilloscope XY mode to plot an analogue clock.
- C++ program
- Single USB provides power, programming and control.
- Solder-less construction.
STEP 1: Construction
Image #1: Circuit diagram - the resistors forming the DAC network are all identical values, and connect directly to the GPIO ports on the Raspberry Pi Pico.
Image #2: Layout details - created using Fritzing.
Image #3: Actual layout - same as Fritzing diagram. This is only a proof of concept, so I have just used a solder-less breadboard
STEP 2: Programming the Raspberry Pi Pico
The code is written in C++, and if you want a closer look at how it works, the source is available from the Github repository.
If you just want to use the code, the repository also includes a '.UF2' file which is pre-compiled and ready to run.
To install the UF2 file on the Raspberry Pi Pico...
- Download the clock.uf2 file from the Github repository.
- On the Raspberry Pi Pico, push and hold the BOOTSEL button and plug the Pico into the USB port of your computer. Release the BOOTSEL button after the Pico is connected.
- The Pico will mount as a Mass Storage Device called RPI-RP2.
- Drag and drop the clock.uf2 file onto the RPI-RP2 volume.
- Once copied, the Pico will re-boot and execute the code.
STEP 3: Technical Details
Image #1: R-2R Resistor Ladder...
There are plenty of articles already explaining R-2R DAC operation. I'm not a mathematician, so I wont be covering it here. But if you do want want to see the maths behind the resistor ladder network, a good place to start is the page on Wikipedia. Or, I have put together an Interactive Simulation showing circuit operation.
Stray Capacitance (and the choice of resistor values)...
I originally built the circuit using a 10K resistor network. My thinking at the time was this would simplify construction. But results were disappointing, with frequency response dropping off rapidly for frequencies above 100KHz. After much Googling, I realised the issue was due to stray capacitance.
The combination of the resistor network and the stray capacitance creates an RC filter. So I applied some maths to the issue...
Image #2: At low frequencies (100 Hz) my digital scope measures Vout Pk-Pk = 3.26 volts
To find -3DB multiply Vout by 1 over square root of 2 = 2.3 volts
So I can use the digital scope to measure the output voltage and vary the frequency until I get 2.3 volts. The scope reading jumps around a bit, so I measured two values. 2.2 volts is below the -3DB point and 2.4 volts is above the -3DB point.
Varying the frequency and observing Vout gives...
Image #3: Vout = 2.2 volts @ F = 133KHz
Image #4: Vout = 2.4 volts @ F = 111KHz
Taking the output impedance of the R-2R network as 10K, we can plug these values of F into the formula
C = 1 / (2 * Pi * R * F )
F=111KHz: gives C = 143pF
F=133KHz: gives C = 119pF
So the stray capacitance would seem to be somewhere between 119pF and 143pF.
Using R=10K gives a -3DB frequency of between 111KHz and 133KHz (observed value)
Using R=165 ohms gives a -3DB frequency of 14MHz (calculated value)
Or, to put it another way, using high value resistors in the R-2R network is a really bad idea.
Screen burn...
Just a reminder... leaving the clock running for extended periods on a CRT based oscilloscope, is going to be really bad for the tube, leaving a permanent imprint of the clock face burned into the tube phosphor.
STEP 4: Interface Settings
These settings are only recommendations, and reflect the way I have my system connected. The circuit should work with most terminal emulators on most operating systems.
Operating System:
- Windows 10 or later - earlier version of Windows won't recognise the USB connection.
Oscilloscope:
- Horizontal (X) deflection: => Channel 1 (yellow)
- Vertical (Y) deflection: => Channel 2 (blue)
- Probe scale: x 1
Terminal software:
- Putty
- Speed: 115200
- Local echo: auto
Clock Application (Supported commands):
- ? - Help
- T - Set time
- Notation: HH:MM:SS or HH,MM,SS
- HH can be either 12 or 24 hour notation. e.g. '03:00:00' is the same as '15:00:00'
- Delimiter can be either ':' or ','. e.g. '15:00:00' is the same as '15,00,00'
- MM is in the range 0<=MM<=59
- SS is in the range 0<=SS<=59
- Leading zeros can be omitted. e.g. '1:2:3' is the same as '01:02:03'
- Trailing parameters can be omitted. e.g. '12:15' is the same as '12:15:00'
- L - Set level
- Notation: 2 digit percentage 0<=NN<=100
- V - Version info
- X - Invert X axis
- Y - Invert Y axis
rafununu 3 months ago
