Introduction: Outdoor Benches
I built some outdoor benches to replace some old benches that we had been using for some time now. if you want new benches here what you will need
4 4x4 that are 6 feet long
4 2x6 8 ft long
4 1x3 8 ft long
all of these should make one piece extra just in case you mess up
you will also need a kreg pocket hole system
2 clamps (optional)
any type of saw (hand saw not recommended)
orbital sander
screws
drill bit
any measuring tool
a right angle (optional)
Step 1: Markings
these markings can be different depending on the style of the bench you want these making will be keeping the width of the blade in mind.
Step 2: Cutting
I used a DeWalt miter saw for these cuts, also make sure you keep the width of the blade in mind when making these cuts. my blade with was 1/8 of an in inch. just cut on the marking to get all the correct pieces for the bench.
the cuts
cut the 2x6 8ft into 2x6 6ft
cut the 1x3s into 1x3 1ft 6"
cut all the 4x4 8ft in to 1ft 8" peices
Step 3: Markings
take a pencil and mark were all the pieces will be glued on.
we also have to make some pocket holes on the wood so you will also be making more markings.
