Introduction: PCB Basics for Beginners
What are PCBs?
PCBs or Printed Circuit Boards have become thoroughly ubiquitous in today’s world. Before PCBs, all components were connected by mainly using wires. A PCB is a plastic board strengthen with glass, with Copper traces and pads covering it which connect together. These copper traces allow current to flow through the PCB, providing power to the different components that are situated on the board. This article will serve as a complete guide towards PCB basics and will also help you understand what PCBs are all about.
We are extremely thankful to JLCPCB for sponsoring projects on this website and youtube channel. JLCPCB is the foremost PCB prototype & manufacturing company in china, providing us with the best service we have ever experienced regarding (Quality, Price Service & Time). We strongly recommend ordering PCBs from JLCPCB, all you need to do is just download the Gerber file and upload it to the JLCPCB website after creating an account, visit their website to look for more!.
Step 1: Classification of PCBs
Starting our guide on PCB basics, we will first look at the classification of PCBs.
PCBs can be classified on the basis of:
- Mounting Technology
- No. of Layers
- Flexibility
Step 2: Mounting Technology
Through-hole PCB
In a through-hole PCB, components are placed on the board by drilling holes through the PCB board & mounting the part, with solder pads on the opposite end. This method is easy to implement in single layer PCB but gets far too complex for Multi-layer PCBs where drilling holes through the PCB is more difficult & expensive
Step 3: Surface Mount PCB
In this type of PCB, components are small in size because these components have very small lead or no leads are required for mounting on the board. Here, in this technology, SMD components mount directly on the surface of the board, with no need to drill holes on the PCB.
To Buy Custom-built PCBs at amazingly low rates 2$ for 5 PCB’s Please visit: www.jlcpcb.com
Step 4: Classification on the Basis of Number of Layers
Single Layer PCB
Single layer PCB is the most simple & commonly used PCB in today’s design market. As the name suggests, this type has only one layer of a conductive material such as a copper sheet.
Double layer PCB
It consists of two layers of conductive material. in this type of PCB, a thin layer of conducting material, like copper is on both top and bottom sides of the board.
Multi-layer PCB
A Multi-layer PCB has at least 3 conductive layers of copper. It can be considered as batches of double-layer PCBs where the 2 conductive foils are glued and laminated with a dielectric sheet placed in between them.
Step 5: Classification on the Basis of Flexibility
Rigid PCB
In Rigid PCBs, solid materials restrict the twisting of the PCB. Rigid PCB have different layer configuration like single layer, double layer and multi-layer Rigid PCB. Shape of this PCB does not change after installation.
Flex PCB
Flex PCBs, get their name for their flexible nature of enabling any circuitry to fit any electronic device or a product, as opposed to building a separate housing to conform to the circuit board. This type of PCB uses flexible plastic material like polyimide, PEEK (Polyether ether ketone), or transparent conductive polyester film. It saves space and is also very light in weight.
Flex-Rigid PCB
Containing a combination of both flexible & rigid PCBs, the Flex-rigid PCB boards consist of multiple layers of flexible PCB attached to a number of rigid PCB layer. They are ideal for their use in medical electronics, in devices such as pacemakers, pulse oximeter, etc.
In Conclusion, this guide is a comprehensive approach to PCB basics for beginners to electronics.
