PIR Motion Detection Sensor With Arduino
Intro: PIR Motion Detection Sensor With Arduino
STEP 1: Things You Need
Here’s the required parts for this project
1x PIR Motion Sensor (HC-SR501)
Arduino UNO
1x LED
Jumper Cables
STEP 2: Schmatics
Assemble all the parts by following the schematics below.
STEP 3: Code
Upload the following code.
int led = 13; // the pin that the LED is atteched to
int sensor = 2; // the pin that the sensor is atteched to
int state = LOW; // by default, no motion detected
int val = 0; // variable to store the sensor status (value)
void setup()
pinMode(led, OUTPUT); // initalize LED as an output
pinMode(sensor, INPUT); // initialize sensor as an input
Serial.begin(9600); // initialize serial }
void loop()
val = digitalRead(sensor); // read sensor value
if (val == HIGH)
// check if the sensor is HIGH
digitalWrite(led, HIGH);
// turn LED ON delay(100);
// delay 100 milliseconds
if (state == LOW)
Serial.println("Motion detected!");
state = HIGH;
// update variable state to HIGH
else {
digitalWrite(led, LOW);
// turn LED OFF delay(200);
// delay 200 milliseconds
if (state == HIGH)
Serial.println("Motion stopped!");
state = LOW;
// update variable state to LOW
STEP 4: Detecting Motion
So after connecting everything together and uploading the code into arduino you can see whenever any living being comes anywhere near to sensor then it gets triggered and LED turns ON and you can use this sensor in your motion triggered project.
