Introduction: PIR SENSOR, NEOPIXEL STRIP AND LIGHT BULB (GROUP 3)
Important components are prepared and used for the construction of this circuit.
Components used are PIR sensor, Neopixel(strip 4), LED, Breadboard, Arduino Unoboard and Resistor.
Step 1: Connecting PIR Sensor
Connect the Signal terminal to pin 2. Connect Power terminal to 5V. Connect Ground terminal to GND.
Step 2: Connecting LED (light Bulb)
An LED is connected with a resistor of 1kilo ohm to pin 13.
Step 3: Connecting NeoPixel
The Terminal IN of the Neopixel is connected to pin 6 with a resistor of 1kilo ohm. Connect Power Terminal to 5V. Connect Ground terminal to GND.
Step 4: The Complete Circuit
The circuit is completed and sensor is working as our expected result.
