POV by Using Seven Segment Display
Intro: POV by Using Seven Segment Display
In this tutorial we are going to see how to make pov display by using old seven segment display
STEP 1: Components Required:
Arduino (use any Arduino boards)
Old LCD display
Reed Switch (1)
9V Battery and Adapater
1k Resistor (2)
DC motor
Wheel (1)
Magnet (1)
Few Wires
12V use old charger
STEP 2: Soldering Seven Segement Display:
Solder the apporiate pins to turn on straight array of led inside the seven segement
After checking few hours i find right pins for me . Because it vary for other seven segment display I took this
seven segment from OLD oninda dvd player
STEP 3: Assembling:
1) First place the seven segement in a rectangular pvc pipe by using plastic zip lock
2) Now make the rectangular pvc flat and put two holes for fixing arduino
3) Fix the arduino with pvc by using screw and nut
4) Connect Battery to arduino Vin pin and Gnd
5) Connect reed switch state dectection circuit under the pvc
6) Now Glue the wheel under the pvc
7) place a magnet to turn on the circuit
8) Now connect it with motor
STEP 4: Circuit Diagram :
Make the circuit as per the schematics
Instead of Using Seven segment Display You can also LED
Before assemebling this part i have the LED in seven segment display
I have used the reed switch before . When the pov display start the spin it will print
the word entire circle it doesn't have proper start and stop position to fix this problem
I used a reed switch . Reed Switch (It is simple a switch in which circuit will be closed when we bring a magnet field close to the switch)
When it sense the magnet field it start to print the word in same position
Instead of reed switch we can also use Hall effect sensor , Proximity sensor
