PSP Cardboard Arcade Stand
Intro: PSP Cardboard Arcade Stand
Alright, this instructable will show you how to make a stand similar to Duobix's DS cardboard arcade stand except this one is for the PSP (phat PSPs only, but i don't know if this will work for the slim)! So follow this tutorial and you'll have a PSP cardboard arcade stand of you very own.
STEP 1: Materials
Ok, time to gather your materials:
!PSP! If you don't have one then what are you doing here? o_o Ha, just kidding. But then again I look at instructables that require everything I don't have. (including knowledge of the subject.) Moving on!
!Cardboard! I'm pretty sure that anything will do. Try different thicknesses to your liking. For my first stand i used an old Converse shoe box and it worked perfectly.
!Knife/Scissors! I'm using my handy X-acto knife and a pair of scissors. (Pairs are two, right?)
!Pencil/Pen! For making marks and stuff.
!Glue! I used some Elmer's and a hot glue gun for the spaces that may be left over. You don't need the glue gun if you don't have it though.
!Ruler! For making straight edges and measuring stuff.
!Any decorations you might want to put on the stand! I just used some flat black spray paint and paper for my first one.
!You also may need a charger, just so you have a good guess of how big the feeding holes should be!
Once you have all these things, move on to the next step!
STEP 2: Begin!
As in the DS stand, we start by drawing out what the stand will look like. I drew out the right side of the arcade booth right on to the cardboard. For the measurements, just look at the diagrams below. After you have drawn out all of the pieces, begin cutting them out. (For the sides and top and bottom, you can just trace one of the pieces.) Make sure you have the right pieces in the right places so you don't get confused. (Don't take the drawing as the real deal. Just follow the basic shape and the measurements and you should be fine.) Very sorry about the mixing of measurements.
The top-most front piece is 3cm x 9.8cm.
The top slanted piece should be 2cm x 9.8cm. (This is the one that pushes out a little bit more.)
The bottom slanted piece is 2.3 x 9.8cm. (On a real arcade booth, this would be the control panel.)
As for the "screen" i did not put any cardboard so that i could still access the charger and for space issues that i had later in the project. I also left the indenting part of the top alone so there would be a bit more space for the PSP. I hope this page is not confusing in any way. If you come to any problems, just leave a comment and I will try my best to answer it.
STEP 3: Decoration !Only If You Are Spray Painting!
Lay out one piece at a time on a piece of scrap cardboard or sheets of newspaper to protect your work surface from over spray. Apply the paint to each piece according to the can directions. Let these dry and move on to the next step.
STEP 4: Feeding Holes
Take the right side and back pieces and pull them aside. Grab your PSP charger jack and take some measurements. Look at your two pieces and think of where you will put the feeding holes. I chose to put a hole in the lower part of the back and another hole near the protruding "corner" where the PSP will sit. You can put these holes anywhere you want, or not at all.
STEP 5: Assembly
THIS STEP MAY SEEM CONFUSING, JUST LOOK AT THE PICTURES WHEN YOU NEED GUIDANCE
Time to put it all together. Take one of the top/bottom pieces and lay it paint side down(if you did paint it.)
PIC 1: MAKE SURE THAT EACH PIECE IS FACING THE RIGHT WAY BEFORE GLUING!!!! Apply glue to the side you are putting the first piece on. *I suggest applying the glue to the left side with the left piece so you will have a support in this next part*
PIC 2/3: Now stick that piece on and apply pressure while it dries. While still holding your first piece (left side of stand) apply glue to the back of the left piece and along the back of the bottom piece. Stick the back side on to the glue and let dry.
PIC 4/5: Glue along the right side of the back and the right side of the bottom and stick on the right side of the booth.
You may want to feed the charger into the back through the inside of the booth and out the side now because you may not be able to later.
PIC 6: Glue the lower front piece onto the three front sides.
PIC 7/8/9: Glue on the top, high front, and indenting pieces.
STEP 6: Done
There you go, your very own PSP arcade stand. Customize and modify to your preferences and likings. Please send pictures and videos of your stands in comments. Thanks for checking this out.
42 Comments
Zia Kaudeer 12 years ago
imthatguy1125 15 years ago
muffinhead 15 years ago
foxtrot4697 14 years ago
doughnutguy1 14 years ago
drackeo 13 years ago
dylanlarson 14 years ago
Silentz 14 years ago
muffinhead 14 years ago
griffy55 15 years ago
rada194 15 years ago
ReCreate 15 years ago
