PVC Bench-top Bike Repair Stand
Intro: PVC Bench-top Bike Repair Stand
A simple and inexpensive bike repair stand for the bench-top. It's not quite as sturdy as the commercial floor-standing models but it works really well and you can spend the money you save on that Campy derailleur set you've always wanted.
STEP 1: Cut PVC Parts to Length
Parts List (PVC is 1 1/4" schedule 40):
(4) Tees
(2) 90 degree elbows
(2) 45 degree elbows
(4) Splices - 2"
(1) Lower upright - 7 1/2"
(1) Upper - 9 1/2"
(1) Horizontal extension - 4 1/4"
(2) Utility hinges - 1"
(1) Clasp
(2) Galvanized conduit clamps - 1 1/2"
Foam pipe wrap
PVC glue
(4) Tees
(4) Splices - 2"
(1) Upper - 9 1/2"
(1) Clasp
Foam pipe wrap
PVC glue
STEP 2: Cut the Tee for the Clamp
I used a band saw to cut in half the PVC tee used to make the clamp. The cut needs to be pretty straight in order for the clamp to hinge properly.
STEP 3: Assemble
Dry assemble all the PVC parts and mark them with a Sharpie for proper alignment when you're ready for final assembly. Glue all the pvc joints. You might want to take the extra step of cleaning all joints with PVC cleaner. You don't want your stand falling apart and your bike crashing to the floor.
Install the hinges and clasp on the tee you cut in half to finish the clamp assembly.
STEP 4: Attach to the Bench Top
Position the front legs of the stand near the front edge of the bench and use the 1 1/2" conduit clamps to hold the back of the stand securely to the bench.
STEP 5: Use It
Wrap a 4" piece of foam pipe wrap around the seat post of your bike to protect it. Open the clamp and lift the bike so the seat post is inside the open clamp. Close the clamp and secure the clasp. Work on your bike.
42 Comments
jcharbonnet 9 years ago
is it cheaper to buy the pvc and do it your self or buy on off of ebay
ymizrachi 10 years ago
the stand flexes a bit so i had some 2 part high density polyurethane foam laying around. just filled the pipes with it and it feels really strong now. it wont flex anymore and you can hammer out the headset like on a pro workshop stand..
imarunner2 10 years ago
the stand flexes a bit so i had some 2 part high density polyurethane foam laying around. just filled the pipes with it and it feels really strong now. it wont bent and you can hammer out the headset like on a pro workshop stand..
the bike still moves a bit so i had some 2 part high density polyurethane foam laying around. just filled the pipes with it and it feels really strong now. it wont bent and you can hammer out the headset like on a pro workshop stand..
Old Duf Fuss 10 years ago
Love it!!
Thank you.
NSDude 16 years ago
shewitti 12 years ago
imarunner2 16 years ago
brianandkathym 12 years ago
Galvanized Pipe instead of PVC and With all the Work on doing repair of Bicycle's
I have found out that using Galvanized Pipe I could have put up 3 to 5 Bike on their own Maintenance Bike Holder. Job well done.
Science Swine 13 years ago
Joe_080 17 years ago
ebrady 16 years ago
Details of my work can be found here.
ebrady 16 years ago
andrew. 16 years ago
jon e rock 16 years ago
