Introduction: PVC Bugle
Have you ever wanted to try to play a bugle but never enough money or donʻt know how well I can teach you how to make and play one.
Step 1: Step:1
Step 1: Get a 30 inch piece of PVC and cut it into a 9 inch piece and a 3 inch piece so that you can have more pieces to build it. The diameter is ½ of an inch and the length of the pipe is 9 inches.
Step 2: Step:2
Step:2 Get a 30 inch piece of PVC and cut it into a 9 inch piece and a 3 inch piece so that you can have more pieces to build it. The diameter is ½ of an inch and the length of the pipe is 9 inches.
Step 3: Step:3
Step 2: Get plastic connectables to connect the PVC pipes and build it. You need elbow pieces like these.
Step 4: Step:4
Step 3: Then turn the PVC and plastic so that you can blow it and lastly get a mouthpeice The moutheice’s diameter must be 1 inch.
Step 5: Step:5
Get Duct tape and a saw so that you will be able to cut and tape the parts together. When you get all the pieces of PVC pipes cut then you can tape it all together
Step 6: Step:6
When you get all of the pieces in this order so have the 9 inch PVC then add the elbow piece then put the 3 inch piece or a 2 inch piece then put another elbow piece then put the last 9 inch piece then put the mouthpiece on the first 9 inch piece.
