PVC FIG RIG
Intro: PVC FIG RIG
This is a Fig Rig Steadicam made from PVC pipe. This parts, which can be picked up at Home Depot, cost about $10. Assembly took 30 minutes.
STEP 1: PARTS LIST
Here is what you need to build the Fig Rig --
3/4" PVC PIPE - Cut to :
6" Length (6x)
3" Length (2x)
2.5" Length (4x)
1.5" Length (4x)
45 Degree Connector (10x)
"T" Connector (2x)
"Cross" Connector
Endcap with 1/4" hole drilled in middle (2x)
1/4" 41/2" Long Size 20 Carriage Bolt
1/4" Wingnut
1/4" Nuts (2x)
1/4" Fender Washer
PVC Cement (Optional)
6" Length (6x)
3" Length (2x)
2.5" Length (4x)
1.5" Length (4x)
"T" Connector (2x)
"Cross" Connector
1/4" Wingnut
1/4" Nuts (2x)
1/4" Fender Washer
STEP 2: ASSEMBLY
Assemble the main body as shown in the picture below. The camera mount will come next.
STEP 3: Camera Mount
1. Drill a 1/4" hole through the middle of the PVC endcap.
2. Screw a nut onto the carriage bolt about halfway down.
3. Thread the bolt through the endcap.
4. Connect the endcap to a 1 1/2" length of PVC.
5. On the outer part of the carriage bolt, screw on another nut and tighten it with pliars.
6. screw on the 1/4" wingnut.
7. Place a fender washer above the wingnut.
8. Screw the bolt into the camera bottom and then tighten the wingnut.
9. Place the assembled mount into the "Cross" PVC connector and cement it.
STEP 4: FINISHED PRODUCT
Shoot smoothly with your new fig rig!
25 Comments
shakescar 10 years ago
For the cross piece, I used 3/4 inch PVC, and stuck a piece of dowel in each end and secured through the bike wheel with drywall screws and then ran 1/4 bolts through the pipe and dowel to keep the mount upright and serve as accessory attachments, if needed. Hope you guys like it.
giulio.m 11 years ago
kathynv 11 years ago
Brother_Bear 17 years ago
vigorotaku 11 years ago
I set up a Rig with the Atomos Ninja-2 on the Nikon D4.
From my blog:
Once set up all I have to do is start Live View (in video mode) and start the Ninja-2 recording. When I cycle the Live View button on the D4, the Ninja-2 starts recording when Live View is on and stops when I shut it off. Each time the Ninja-2 creates a new file for the next take. I turn on the Focus Peaking to ensure perfect focus and it stays on the whole time (does not reset when Live View is cycled). Perfection!
Check out my rig
here
Dan at Vigorotaku
a splosion 12 years ago
cmilnes1 12 years ago
ionic 12 years ago
My thoughts would be to somehow reduce the rigidity of the cross-bar section, using yet smaller PVC diameter and a longer piece. You could even remove the top straight section of PVC. All of these changes would allow greater flexibility and would reduce the motion transferred to the camera. Bottom line, this design is for very basic use. It would be useless when attaches to a bike, scooter, or other moving object.
tmilliken 12 years ago
CrossisBoss 12 years ago
shoeshinecity 15 years ago
goldenfall 13 years ago
shylock 15 years ago
Twist 15 years ago
habiat23 16 years ago
febert 17 years ago
The Moog 17 years ago
erfonz 17 years ago
loudboy 17 years ago
