PVC ROD Rack
Intro: PVC ROD Rack
Quick ,neat and easy way to store your fishing rods on ceiling beams in the garage
Needed parts
i)Lenght of 50mm PVC
ii)some drywall screws
iii)Hacksaw,5mm drillbit,a drill and Phillips screwdriver
1)Get a length of 50mm diameter PVC and cut it into 15cm pieces
(Each rod needs 2 pieces )
2)Drill a 5mm hole in the centre of one side of each PVC piece (this is where you pass the phillips screwdriver through)
3)Cut a 1cm wide slit down the side of the front PVC pieces (This makes it easy to add/remove the rods)
4)Put the phillips screwdriver through the hole you drilled and add a drywall screw on top of it and screw it through the side of the PVC and into the ceiling beam do the same for the front piece
Needed parts
2 Comments
bmcmahon3 8 years ago
Great idea.
tortugo 9 years ago
