PVC Toothbrush Holder - Inside Cabinet Door
Intro: PVC Toothbrush Holder - Inside Cabinet Door
Simple project. Minimal tools, no gluing. Get your toothbrushes off the vanity and away from germs.
I did see this project done on the Internet.
STEP 1: Cut Tubes and Drill
I cut 1" PVC into 4.5" lengths. Bought caps for the bottom. Drilled a hole in each 1" from top to hold hook.
STEP 2: Attach Caps
Don't glue them.
STEP 3: Attach Felt Pads If Desired
Makes less noise when you open and close cabinet.
STEP 4: Center the Middle One
Measure and mark a good spot on your cabinet. Make sure your toothbrush and PVC clear anything in the cabinet. Center and attach a 3M hook on the cabinet. I used the ones that you can pull off later.
STEP 5: Attach the Other Hooks
Use the other tubes as a guide on where to line up the others.
STEP 6: You're Done
Enjoy
4 Comments
BeachsideHank 8 years ago
Good to make them removable for dishwashing, most certainly they will fill with schmutz in the tube bottom after a while. ☺
Dwargh 8 years ago
'tis strange to see the german word "Schmutz" with the right meaning in here ;) hehe
Yonatan24 8 years ago
If I were you, I'd drill a small hole a the bottom to help any water drip out. If you don't do this, It might cause mold at the bottom
Asgardian 8 years ago
