PVC USB/FM/Bluetooth Player
Intro: PVC USB/FM/Bluetooth Player
STEP 1: Materials Needed
- PVC pipe 2.5"
- Lithium Battery Alexpress
- PAM 8403 Amplifier Aliexpress
- TP 4056 Lithium charging board Aliexpress
- MT 3608 Step up module Aliexpress
- 1S BMS Aliexpress
- Mp3 Decoder board with built in bluetooth receiver Aliexpress
- 2* 4ohm 3watt Speakers Aliexpress
- Slide Switch Aliexpress
- FM Antenna Aliexpress
- 3mm LED Aliexpress
- Epoxy glue (I used Araldite)
- Wires
STEP 2: Design
Cut the PVC according to the design given and cut holes for the electronics.
STEP 3: Side Pannels
I took plastic casings from old DVR Tape. Mark and cut the plastic as per requirement as shown in pictures.
STEP 4: Making the Door
- Mark square area to make a door and cut (Pics 1 to 4).
- Drill a hole for making a lock (Pic 6).
- Take a nail, bend and insert into the hole to make it as a lock (pics 7 to 11).
- Take plastic empty refill from a pen and cut into 3 parts, insert metal rod / wire into the refill and then glue both the ends (Pics 12 to 14).
- Glue the center part of the refill to the door and remaining two to the body(Pics 15,16).
STEP 5: Speaker Holes
Drill speaker size hole with hole saw. Insert the speakers, apply hot glue and then solder wires.
STEP 6: Wiring
Wire according to the schematics. Drill a hole for FM antenna and connect the wire. Hot glue all the electronics components inside PVC.
STEP 7: Gluing
After wiring, except mp3 decoder and slide switch, I sealed everything by gluing with araldite.
STEP 8: Paint Job
Sand everything and paint with white color. It is good to use plastic primer for even better finish. Paint top coat with 705 GOLD and apply clear coat.
STEP 9: Finally
Use the left over PVC that you cut previously for the legs. Paint the legs and attach to the player with screws. Finally it's done....!
6 Comments
roma19672 6 years ago
Hello.Tell me, this module in FM mode memorize a lot of empty settings in memory? Is your method of coloring the plastic successful? Does it resist erasure and scratches well?
sandilya.anisetty 6 years ago
Mohammade9 6 years ago
The class-D amplifier is super efficient, I am sure your battery lasts hours.
This is a very creative yet high end, complete, while power & cost efficient project.
I really love this!
-- Greeting from Indonesia ;]
СергейЧ 6 years ago
Nice job! How long does the battery last?
