Paint Your Drum Kit With Rustoleum Brand Spray Paint
Intro: Paint Your Drum Kit With Rustoleum Brand Spray Paint
Give your old dirty mix-matched drum kit a new look with a few cans of spray paint.
STEP 1: 1. Get Your Drums
The drum kit I have was black and brown and a couple different brands. It looked like it matched but was not nice to look at and dirty as hell.
STEP 2: 2. Take It Apart
Take all the rims , hardware, and heads off the drums. Unscrew all hardware and keep the accompanying screws in labeled bags, envelopes, etc. so nothing is lost.
STEP 3: 3. Clean It Up
Strip all drums of their hardware and clean as much as possible with soap, water and a rag or sponge.This is a naked cleaned bass drum.
STEP 4: 4. Prime the Hardware
I took all of the hardware from the rack from the hi tom and screwed each piece onto a piece of cardboard and taped off all the holes where the lugs would enter so no primer and paint could enter these areas. I used one piece of cardboard for each drum because I did them at different times.
Prime away!
Prime away!
STEP 5: 5. Start Painting
After priming paint with your desired color. This is Sunshine Red.
STEP 6: 6. More Painting
You will prime and paint the rims in the same fashion of course but will not need to screw them to any surface since you are painting the entire object.
STEP 7: 7. Tom Time
The toms have a plastic shell on them so I purchased Rustoleum plastic spray paint in Safety Green. These will not need to be primed before painting. I taped the inside where the holes for the hardware go through so no paint would go inside the drum.
STEP 8: 8. Clear Coat
Before screwing everything together I hit everything with quit a few hits of clear coat to prevent some scratches. Doesn't make it impenetrable, but helps for the little things.
STEP 9: 9. Re-assemble
Screw everything back together. White drum heads are always the nicest and classiest.
STEP 10: 10. Rock & Roll
Boo-ya.
26 Comments
Miss Mango 4 months ago
Daniel adetona 1 year ago
nicholasmooresup 4 years ago
callum670 5 years ago
NicholasH90 6 years ago
Good Luck Skinners!
CoreyA 9 years ago
oh17krupa 10 years ago
joepalumbo 12 years ago
jlane18 11 years ago
troy.brown 12 years ago
jlong16 12 years ago
teejeff89 14 years ago
Jonny Mohawk 14 years ago
ntagn33 14 years ago
ANTQNUT 14 years ago
Drum_Dude 14 years ago
DecimusOctopus 14 years ago
Shut Up Now 15 years ago
thebboy 15 years ago
Hellchild 15 years ago
