Paint Brush Stylus for Ipad. Used on Sketchbook PRO!
Intro: Paint Brush Stylus for Ipad. Used on Sketchbook PRO!
When I got my Ipad, the first App I downloaded was Sketchbook Pro. I've been using it on wacom for work and loved it. I quickly realised that drawing with fingers on an Ipad was much more difficult, so I decided to design my own stylish stylus. It took me a while to understand what makes a stylus work correctly, so I hope you'll learn from my mistakes.
Here is how to make a fun and effective stylus for Ipad and Iphone.
STEP 1: You Will Need
You will need :
A metalic paint brush (8mm diameter)
A standard eraser tip
Conductive foam (Used to hold electronic chips)
STEP 2: Cut the Eraser
Cut the pointy part of the eraser. You will only need the cylinder part.
STEP 3: Foam
Cut a corner of the conductive foam as shown.
STEP 4: Insert
Insert the conductive foam inside the rubber tube.
STEP 5: Assembly
Insert the back of the metalic paint brush on the other side of the rubber cylinder. Make sure you leave enough surface foam surface for it to be detected. Also make sure that the metal isn't sticking out of the foam or you will scratch your screen.
STEP 6: Try
Try your new stylus and adjust it so it work perfectly for you. You will also realise that, (if you have an Ipad 2) you stylus can be magnetised by the frame and held in place while doing something else.
21 Comments
nobhasorn 7 years ago
Hi! I made Homemade Stylus too.
Please visit : https://www.instructables.com/id/How-to-Make-the-B...
Thank you.
Alexwang 8 years ago
I prefer mybrushes as it is easier to use and more intuitive.. good ipad drawing app
pieman63 12 years ago
rgerber1 12 years ago
I get free shipping because I am an Amazon prime member for my Kindle fire.
this is a good instructable if that is what you want to do.
Samuel Bernier 12 years ago
LiveCrafts 8 years ago
In case you lose them!!!
dagob 11 years ago
arbish 10 years ago
Soap/fabric softener, I like this post! Perhaps you could simply soak it up with a Copic Marker tip. After all, the Copic Marker experience is what i'm trying to create with my iPad.
Too bad Sketchbook Pro would still need pressure sensitivity to really complete the experience.
I love old tech, especially when it's combined with new tech.
varsik 12 years ago
I didn't have a metal tube so I used a disposable pen, ran a wire from the pen to some ally foil.
dawnweck 12 years ago
XTL 12 years ago
sgleason1 12 years ago
Punknudder 12 years ago
The finest tip I can get to work on my screen is the tip of a AA battery, but the screen's detection is very unreliable, leading to broken lines and undetected presses.
datacomm 12 years ago
sarawelder 12 years ago
