Introduction: Pallet Coffee Table
How to make a simple stylish pallet coffee table for loft or mancave without having a workshop.
Step 1: Tools
Tools needed:
- pallet
- caster wheels
- tack cloth
- screws 1/4 inch
- screwdriver
- power screwdriver
- brush
paint brush
orbital sander
80/150/220 grit sandpaper
woodstain
- wood finish
Step 2: Sand the Pallet
This specific pallet was Heat Treated (HT) which means no chemicals were used.
Take the orbital sander and sand the whole pallet, starting from 80 grit to 220.
Brush away wood dust and clear with cloth dipped in mineral spirits.
Step 3: Staining the Table
The stain used was Varathene Woodstain Golden Mahogany.
Rub in the stain smoothly with tack cloth though the entire pallet.
Go with the grain of the wood.
Let dry for 12 hours.
Later on I decided to add some more table space with two more boards cut to fit.
Step 4: Coat With Polyurethane
Coat 3 times with 8 hours in between with Varathane polyurethane semi-gloss (depending on what coat used will cange effect in the end).
Step 5: Adding the Caster Wheels
Align caster wheels under pallet so they are not to close to the edge and not to close to the nails.
Screw in 1/4 screws with power screwdriver and tighten by hand with screwdriver.
Step 6: Enjoy
And there you have it.
Enjoy your coffee on your new table, sitting on a cozy couch by the fireplace.
P.S.
Might use different size screws next time (a bit thinner) some soap and a lighter color stain.
