Pallet Wall Shelf
Intro: Pallet Wall Shelf
I wanted to make a wall shelf.
STEP 1: Prep Pallet
Find a good, clean pallet to form the back of your shelf. I used a random orbit sander with 60 grit paper. I took some wide planks from another pallet for the shelves. I sanded to remove any superficial blemishes. When I removed the boards for shelves, they broke apart, so I edge glued them back together before sanding.
STEP 2: French Cleats
I chose to use French cleats to hang my shelf. They're easy to make, they're strong, and won't tear up your walls. I just cut two 8" planks of 1x4 on 45 degrees with a table saw. Glue them to the back of the pallet and make sure they're at the same height. I sanded the back where I glued them for a good surface.
STEP 3: Mount Shelves
I used corner braces from Lowes so I could hide as much as possible. Regular shelf brackets would also work, but will take away the clean, all-wood look.
STEP 4: Stain
I went for a darker stain. Use cheesecloth to apply the stain, and don't forget to use pre-stain wood conditioner.
6 Comments
shuganne 2 years ago
I'm new here, but when I see pallets used I usually see a caution about using pallets that have not been infused with chemicals to protect against the elements. They may be safe in the open air, but may be toxic in a confined space. 😀
naschd. 8 years ago
I dont like those pallet projects , but I must say, in your case, result is really nice. Hope you made it with very smooth finish ( I mean wood surface). I love color you made it with, and visible nodes on wood. It s really nice idea if you have some old spare pallets with no use or if you can get some "old wood" for free of charge and "re-use" it.
My tip: You should soften the edges and paint this one wall with white or fair brown ( rather white coffe ) color paint for better contrast. ( just my opinion )
but at all it looks nice ;)
wabrown14 8 years ago
Looks awesome! Keep it up!
ahmed1137 8 years ago
ClenseYourPallet 8 years ago
DIY Hacks and How Tos 8 years ago
Awesome display shelf.
