PandaHall Tutorial on How to Make a Chic Seed Bead Choker Necklace
Intro: PandaHall Tutorial on How to Make a Chic Seed Bead Choker Necklace
Wanna make some bright colored accessories to decorate these dull winter days? Take a look at today’s seed bead choker necklace! Fresh colors and low-key style, very chic design.
STEP 1: Supplies Needed to Make This Seed Bead Choker Necklace:
4mm Green Seed Beads
4mm Yellow Seed Beads
3mm White Acrylic Pearl Beads
0.2mm Fishing Wire
Golden Jump Rings
Golden Spring Clasp
Scissor
STEP 2: Make the Basic Green Seed Bead Pattern
1st, Cut about 300cm fishing wire, add the spring clasp and 5 white pearl beads to one end of the wire like picture shows;
2nd, tie a knot to make a pearl bead flower loop and cut off extra wire;
3rd, slide enough green seed beads to the wire, make sure the length fits your neck;
4th, add five white pearl beads onto the wire, cross the wire through the first pearl bead to make a bead hoop, then add a golden jump ring to the bead hoop.
STEP 3: Make the Pearl Bead Decoration Patterns
1st, thread 3 white pearl beads and a yellow seed bead onto the wire, and then cross the wire back through the top pearl bead like picture shows;
2nd, add 3 pearl beads onto the wire and cross the wire through the third and fourth green seed beads like picture shows;
3rd, add 4 pearl beads and a yellow seed bead onto the wire, cross the wire back through the previous pearl bead and add another 3 pearl beads onto the wire;
4th, cross the wire through the first and second green seed beads.
STEP 4: Make More Decoration Patterns
1st, slide 4 pearl beads and a yellow seed bead onto the wire, cross the wire through the top pearl bead and add another 3 pearl beads onto the wire;
2nd, cross the wire back through the fifth and sixth green seed beads and the nearby pearl bead like picture shows;
3rd, add 3 pearl beads and a yellow seed bead onto the wire, cross the wire through the previous pearl bead and add another 4 pearl beads onto the wire;
4th, cross the wire back through the seventh and eighth green seed beads and the nearby pearl bead;5th, repeat all previous procedures to make more decorating bead patterns.
STEP 5: Complete the Seed Bead Choker Necklace
Repeat step 2 and step 3 to make more decorating bead patterns until all the green seed beads are decorated with pearl beads and yellow seed bead patterns, then tie a knot and cut off extra wire.
STEP 6: Here Is the Final Look of This Fresh Colored Beaded Choker Necklace:
The bead patterns are very delicate, but they are not difficult to make at all. Just be patient and try to make one at home!
Inspired by craft idea: http://lc.pandahall.com/craft-ideas/12033.html
