Introduction: Pandahall Original DIY Project - How to Make Handmade Gemstone Bead and Jade Beaded Necklaces
Love gemstone bead jewelry? This Pandahall original DIY project will show you how to make handmade gemstone bead and jade beaded necklaces.
Step 1: Materials and Tools Needed in DIY the Gemstone Beaded Necklace:
19x15mm Oval Gemstone Beads
21x11x10mm Gemstone Pendants
10mm Natural Mashan Jade Beads
10x8mm Abacus Jade Beads
8x6mm Abacus Jade Beads
Platinum Column Magnetic Clasps
0.2mm White Fishing Wire
Stainless-Steel Scissor
Step 2: Make the First Part of the Gemstone Beaded Necklace
1st, cut about 180cm 0.2mm white fishing wire. Then, cross the wire through the right hole of a platinum column magnetic clasp (as shown in the picture);
2nd, add an 8x6mm white abacus jade bead, a 10mm pink natural Mashan jade bead, a white abacus jade bead, a pink natural Mashan jade bead and a white abacus jade bead (as shown in the picture);
3rd, add more 10mm pink natural Mashan jade beads and white abacus jade beads. Then, add a 21x11x10mm white gemstone pendant (as shown in the picture);
4th, add a white abacus jade bead, a 19x15mm purple oval gemstone bead, a white abacus jade bead, a 21x11x10mm pink gemstone pendant and a white abacus jade bead (as shown in the picture).
Step 3: Make the Rest Part of the Gemstone Beaded Necklace
1st, add more white abacus jade beads, gemstone pendants and oval gemstone beads (as shown in the picture);
2nd, thread the wire through the other hole of the platinum column magnetic clasp and make some knots with the wire (as shown in the picture);
Step 4:
3rd, cross the wire through the beads. Then, add 15 8x6mm white abacus jade beads (as shown in the picture);4th, add more 8x6mm white abacus jade beads and 10x8mm pink abacus jade beads. Then, cross the wire through the beads. Make some knots and cut off the excess wire (as shown in the picture).
Step 5: Here Is the Final Look of the Handmade Gemstone Bead and Jade Beaded Necklace.
The well combination of gemstone beads and jade beads in different colors makes this handmade gemstone bead and jade beaded necklace charming. No professional beading techniques are involved in this DIY project. Green hands can have a try!
