Pandahall Original DIY Project - How to Make a Bead and Wire Flower Chain Necklace
Intro: Pandahall Original DIY Project - How to Make a Bead and Wire Flower Chain Necklace
This Pandahall original DIY project is about a bead and wire flower chain necklace. Hope you like this flower chain necklace.
STEP 1: Supplies Needed in DIY the Bead and Wire Flower Chain Necklace:
8mm Clear Round Gemstone Beads
14x7mm Back Rhinestone Beads
2-Hole Seed Beads
2mm White Seed Beads
Golden Spring Clasps
0.5mm Gold Copper Wire
Golden Twist Chains
Golden Jump Rings
Golden Eyepins
0.2mm White Fishing Wire
Needle Nose Plier
Round Nose Plier
Diagonal Plier
Glue Gun
Stainless-Steel Scissor
STEP 2: Make the First Part of the Bead and Wire Flower Chain Necklace
1st, cut a piece of 0.5mm gold copper wire and twist the middle part of the gold copper wire into leaf patterns(as shown in the picture);
2nd, continue to wrap the left wire and the right wire into leaf patterns (as shown in the picture);
3rd, continue to wrap the wires to make a big flower below the flower made just now (as shown in the picture);
4th, fix the wire wrapped flower by wrapping the copper wires and cut off the excess wires. Then, refer to the above steps to make two more such wire wrapped flowers (as shown in the picture).
STEP 3: Make the Second Part of the Bead and Wire Flower Chain Necklace
1st, cut about 150cm 0.2mm white fishing wire. Then, add about 13 white seed beads and 12 blue 2-hole seed beads (as shown in the picture);
2nd, cross the right wire through the leftmost white seed bead and tighten (as shown in the picture);
3rd, cross the wire through the other hole of the adjacent blue 2-hole seed bead. Then, add 2 white seed beads and cross the wire through the other hole of the adjacent blue 2-hole seed bead (as shown in the picture);
4th, refer to the above steps to add white seed beads and cross the wire through the other hole of the adjacent blue 2-hole seed beads (as shown in the picture).
STEP 4: Make the Third Part of the Bead and Wire Flower Chain Necklace
1st, add a blue 2-hole seed bead and cross the wire through the adjacent two white seed beads and the adjacent blue 2-hole seed bead. Then, add a blue 2-hole seed bead and cross the wire through the adjacent two white seed beads (as shown in the picture);
2nd, refer to the above steps to add blue 2-hole seed beads and cross the wire through the white seed beads (as shown in the picture);
3rd, cross the wire through the other hole of the two adjacent blue 2-hole seed beads. Then, add a white seed bead and cross the wire through the other hole of the two adjacent blue 2-hole seed beads (as shown in the picture);
4th, refer to the above step to add white seed beads and cross the wire through the other hole of the blue 2-hole seed beads (as shown in the picture);
5th, tighten the wire and add a blue 14x7mm back rhinestone bead. Then, cross the wire through the beads (as shown in the picture).
STEP 5: Make the Fourth Part of the Bead and Wire Flower Chain Necklace
1st, refer to the above steps to make another blue seed bead flower and a red seed bead flower (as shown in the picture);
2nd, use glue gun to glue the red seed bead flower onto a golden wire wrapped flower (as shown in the picture);
3rd, use glue gun to glue the two blue seed bead flowers onto the other two golden wire wrapped flowers(as shown in the picture).
STEP 6: Make the Fifth Part of the Bead and Wire Flower Chain Necklace
1st, combine 5 8mm clear round gemstone beads with 5 golden eyepins (as shown in the picture);
2nd, make a hoop on the other end of the golden eyepin. Then, combine the three flowers together through two clear round gemstone beads (as shown in the picture);
3rd, cut two equal pieces of golden chain and add them on the two sides of the flowers through two clear round gemstone beads (as shown in the picture);
4th, connect the two ends of the bead and wire flower chain necklace together through golden spring clasps and golden jump rings (as shown in the picture).
STEP 7: Here Is the Final Look of the Bead and Wire Flower Chain Necklace.
What do you think of this flower chain necklace? This bead and wire flower chain necklace looks simple but unique. If you're interested in this bead and wire flower chain necklace, just refer to this free tutorial to make one by yourself.
