Introduction: Pandahall Tutorial on Making a White Pearl Flower Necklace for Girls
Do you like handmade pearl necklaces? This Pandahall tutorial is about making a white pearl flower necklace for girls. Hope you love it.
Pearls have been valued for thousands of years because of their luster and rarity. In this article, you can see a handmade pearl necklace for girls. The great combination of pearl beads and glass beads make this white pearl flower necklace delicate. The following contents are the detail steps of making such a pearl necklace.
Step 1: Materials and Tools Needed in DIY the White Pearl Flower Necklace:
8mm White Round Pearl Beads
6mm White Round Pearl Beads
4mm White Round Pearl Beads
6mm Clear Bicone Glass Beads
6mm Clear Abacus Glass Beads
4mm Golden Round Beads
2x2mm Golden Tube Bugle Beads
Silver Jump Rings
0.3mm Silver-Gray Tiger Tail
Stainless-Steel Scissor
Step 2: Make the First Part of the White Pearl Flower Necklace
1st, cut about 230cm 0.3mm silver-gray tiger tail and thread a 9mm platinum ring clasp to the middle of the tiger tail;
2nd, hold the two tiger tails together and thread 3 2x2mm golden tube bugle beads, a 4mm white round pearl bead, 3 2x2mm golden tube bugle beads and a 4mm white round pearl bead in sequence. Then, split the two tiger tails apart and thread 4 2x2mm golden tube bugle beads to the two tiger tails respectively;
3rd, cross the two tiger tails through a 6mm white round pearl bead. Then, split the two tiger tails apart and thread 4 2x2mm golden tube bugle beads to the two tiger tails respectively (as shown in the picture);
4th, cross the two tiger tails through a 6mm clear abacus glass bead;
5th, refer to the 3rd step to the 4th step to make 4 more such patterns (as shown in the picture).
Step 3: Make the Second Part of the White Pearl Flower Necklace
1st, thread a 6mm white round pearl bead to the left tiger tail and 2 6mm clear bicone glass beads to the right tiger tail. Then, cross the left tiger tail through the 6mm clear bicone glass bead (as shown in the picture);
2nd, thread a 6mm white round pearl bead, a 4mm golden round bead and a 6mm white round pearl bead to the left tiger tail. Then, thread a 6mm clear bicone glass bead to the right tiger tail;
3rd, cross the left tiger tail through the right 6mm clear bicone glass bead (as shown in the picture);
4th, thread a 6mm white round pearl bead to the left tiger tail. Then, thread a 6mm clear bicone glass bead and a 6mm white round pearl bead in sequence to the right tiger tail;
5h, cross the right tiger tail through the left 6mm white round pearl bead (as shown in the picture).
Step 4:
6th, thread 4 2x2mm golden tube bugle beads to the two tiger tails respectively. Then, cross the two tiger tails through a 6mm white round pearl bead;
7th, refer to the above steps to make 3 more such flower patterns;
8th, refer to the above steps to make 3 more such flower patterns (for these three flower patterns, please use 8mm white round pearl beads);
9th, refer to the above steps to make 4 more such flower patterns(for these three flower patterns, please use 6mm white round pearl beads) ;
10th, thread 4 2x2mm golden tube bugle beads to the two tiger tails respectively. Then, cross the two tiger tails through a 6mm white round pearl bead.
Step 5: Make the Other End of the Necklace and Connect the Two Ends
1st, refer to Step 1 to make a corresponding end (as shown in the picture). For the end, please thread 4 2x2mm golden tube bugle beads to the two tiger tails respectively. Then, cross the two tiger tails through a 6mm white round pearl bead. Thread 3 2x2mm golden tube bugle beads, a 6mm white round pearl bead and 3 2x2mm golden tube bugle beads in sequence (as shown in the picture);
2nd, combine this end with a silver jump ring and cut off the excess tiger wires. Then, connect the two ends of the pearl flower necklace together.
Step 6: Here Is the Final Look of the White Pearl Flower Necklace for Girls.
What do you think of this handmade pearl necklace for girls? The main difficult part lies in making the pearl flower. It may take a little time and patience to make this white pearl flower necklace. If you’re interested in this white pearl flower necklace, don't hesitate to give it a try!
3 Comments
6 years ago
Beautiful necklace
Reply 6 years ago
Thanks, friend
Reply 6 years ago
Welcome
