Introduction: Paper Naruto Ninja Star by Andy S. #HMS2020
Today I will teach you how to make a paper Naruto ninja star.
#HMS2020
You will need:
1 paper
1 paper cutter or scissor
NOTE: Make sure to crease all folds very well.
Step 1: The Folding 1
Fold the paper in half and fold it in half again.
Make sure to crease your folds well.
Step 2: The Cutting
Open it up and cut down the folds.
Step 3: The Folding 2
Fold the paper in half then open it up and fold outside flaps to middle crease.
Then fold the top down to the bottom.
Open it all up, you should have 8 squares.
Step 4: The Triangle Folding 1
Fold one end of the corners down to a triangle.
Fold the flap to last crease.
Flip the paper over then fold 2 triangles along the center crease on the same side of the other.
Fold a long triangles on the ones you just folded.
Step 5: The Triangle Folding 2
Hold the top triangle and fold the bottom flap up.
Fold the flap down to the crease 3 times.
Flip over the folded flap to the original side.
Step 6: Simple Folding
Turn the long triangle down.
Fold a small triangle at the edge of the flap up.
Step 7: THE REPEAT
Repeat steps 3-6 for the other 3 pieces. You should have 4 pieces total.
Step 8: Complicated Folding
Hold 2 pieces , take the right piece insert the flap into the pocket between the flap and top/the big pocket.
Hold the whole thing together and flip it over to inset the left flap into the small right pocket.
Flip it back over take the third piece, insert the third piece's flap into the lefts big pocket.
Flip it over and insert left flap into right smaller pocket.
Flip the whole thing over.
Take the last piece, insert it into the bottom big pocket.
While holding everything together flip it over and take the last flap insert it into small pocket.
Finally turn it over fold all center triangles points down into the big pockets of its own.
Step 9: Things to Consider
It was very frustrating the first few times but it is worth it.
A sliding paper cutter is recommended over scissors.
Try taping it together to keep it from falling apart.
