Paper Roller Coasters :)
Intro: Paper Roller Coasters :)
The purpose of this project is to reinforce Newton's Laws of Motion through roller coaster physics. The objective is to have a marble take the GREATEST amount of time to get from the top of the first hill to where the coaster ends.
This instructable has also been submitted into the paper contest. I know the competition is fierce so please vote for me!
Students will demonstrate ability to:
Plan and Create a paper roller coaster
Evaluate and test and retest their roller coaster
Analyze how to best manipulate the forces of friction and gravity
Explain the difference between potential energy and kinetic energy
Calculate problems involving free fall
Create tracks to better understand centripetal force
This assignment can be easily differentiated... make the goal time longer, make the base smaller, limit the amount of paper or tape...
Below is a roller coaster I created as an example for my students. The video starts with an explanation followed by a test run (around the 1:50 mark). I tried to incorporate as many features as possible onto one sheet of card stock. The last step has a video of a paper roller coaster I created a few years ago that includes an elevator.
STEP 1: Materials, Helpful Hints and Rubric
Here's what you're gonna need!
Card Stock Paper (110 # is best)
Tape
A paper cutter
Scissors
Marbles
Patience
Masking tape or Duct tape (you don't need the tape, just the shape of the roll for your loops and corkscrews).
Helpful Hints in no particular order.
Build from the bottom up.
Crease ALL folds.
Make a plan, but be flexible if things aren't working out.
Make good supports.
Keep the decline of your tracks to a minimum (so the marble doesn't roll too fast) unless you are trying to get over a loop or complete a jump.
Rubric
Objective: Work in groups of 2 or 3 utilizing your knowledge of Newton’s 3 Laws of Motion to create a paper roller coaster that can carry a marble for the longest period of time without stopping.
Guidelines:
1. The model should be designed for a glass marble. When released from the top of the first hill, the marble will travel through the entire ride and arrive at the bottom loading platform. (For this project, the marble will be raised by hand to the top of the first hill to start the “ride”.)
2. Your team may use more than one marble.
3. Magnets, electricity, springs, and other forms of energy may not be used this is a “gravity ride” only.
4. No one is permitted to touch the coaster once the ride begins.
5. There needs to be a clear “end” to your ride.
6. You will have only three chances. Your longest time will be the one you get graded on.
STEP 2: Supports
Watch the VIDEO to see how to build them or print out the PDF called "Coaster Element Instructions" in the first step.
STEP 3: Tracks
STEP 4: Loops and Corkscrews
Tape the two tracks together at the ends with about 2 cm overlap.
Cut both walls, down the entire length of the combined tracks, from the top of the wall to the CREASE. Each cut should be about 1 cm apart. If you don't cut all the way to the crease, it will not work.
Wrap the tracks around a roll of masking tape to get the desired shape.
Watch the video for the rest.
The following passage comes from Kids Britannica. The site has a terrific history of Roller Coasters.
"The end of the 19th century, the roller coaster industry was turned upside down. Literally. Flip-Flap Somersaulting loop track rides were first attempted in Paris in the middle of the century. The rides were based on a popular child's toy that exploited centrifugal force to keep a small ball rolling on a looped track without falling off. But passengers found the inversions uncomfortable and dangerous, and looping coasters were not seen again until 1895, when Lina Beecher installed the Flip-Flap Railway at Paul Boyton's Sea Lion Park in Coney Island. Though uncomfortable and dangerous still, the 25-foot circular loop proved popular, whipping the passengers (especially their necks) into a frenzy, before closing after only a few years.
Loop-the-LoopIn an attempt to reduce the high g-forces of the vertical loop, Edward Prescott Coney Island aerial built the 1901 Loop-the-Loop at Coney Island, with a softer, oval-shaped design. It was better crafted than Flip-Flap, but it would still be another 75 years before a successful vertical loop was realized. Although hampered by a low seating capacity that eventually ran it aground, Loop-the-Loop was the hot ticket for coaster enthusiasts for the next six years, until the advent of the first high-speed coaster, Drop-the-Dip (later called Rough Riders). These increased levels of danger brought improvements in safety, such as the introduction of lap bars, which kept passengers from becoming projectiles."
STEP 5: Time Wasters: Toilet Bowl and Funnel / Half Pipe Hybrid
First: Draw the largest circle possible on the sheet.
Second: Cut out the circle.
Third: Decide where the center of the paper circle is located and cut a straight line from the edge of the circle to the point in the middle.
Fourth: Cut a hole just larger than the marble, around the point you located in the middle.
Finally: Overlap the edges of the straight cut to create the funnel and tape into place. The distance you overlap the edges will determine the steepness in the sides of your funnel.
It is important that your funnel be very stable. If your funnel wobbles, the marble will head straight down the hole and you won't end up with an effective time waster.
There are a few other ways to create time wasters. Watch the video below for a few suggestions with instructions. Just be creative!
To create the Funnel / Half Pipe Hybrid, you need to start with a full sheet of card stock.
First: Cut a straight line from the one corner towards the opposite corner, but only make the cut a few inches deep.
Second: Cut a hole just larger than the marble at the end of the straight cut.
Third: Overlap the edges of the straight cut.
Finally: Tape the overlapped edges in place.
STEP 6: Half Pipe
STEP 7: Paper Elevator and Use of Multiple Marbles.
I hope you have a chance to build one of your own. If you do, be sure to send me some pictures and add any advice you have to the comments. Thanks for looking!
58 Comments
Rednexican 11 months ago
scobb14 1 year ago
sunshine688 8 years ago
I am a student at Monroe Elementary. My name is Journey Baham and I am in 7 grade. I don't understand what you mean by we just need the shape of the for the loops and corkscrews. Can't we just use paper?
mg12275 1 year ago
jaydongabell09 1 year ago
darthvadersbro 10 years ago
Biodynamic 10 years ago
Hick Rarrison 7 years ago
You're welcome
Romeo Ching 3 years ago
RebeccaW3 9 years ago
Did you do one pack of card stock per group? I'm loving this as an idea for my Physics classes...
Biodynamic 9 years ago
zhunter9 4 years ago
How much build time do you generally devote to your coaster projects?
I have 6 classes that I see for 4 sessions of about 45 minutes and I’m going to attempt to have them all complete a coaster.
Biodynamic 4 years ago
mdillon25 9 years ago
I teach physical science and my students started this project today. It is the first time I've tried it. I am giving each group 35 sheets of cardstock. I told them this is their "budget". If they need more they will have to buy their own. I am not sure how far 35 sheets will go; I'm on a budget myself.
Thank you so much!
You're very welcome
