Introduction: Paper Stomp Rockets
I used to run a free summertime activity program for kids as part of a past job.
I've got a lot of fun little projects up my sleeves, and I'm always on the lookout for more. One of the more popular summertime activities in my repertoire was homemade stomp rockets. Stomp rockets are great because they are both creative and physical.
There are many versions of paper stomp rockets and launchers out there. They all work essentially the same way: air is forced through a PVC contraption which launches a lightweight paper rocket up into the air. This particular launcher design is a combination of a handful of ideas I've seen, along with a few of my own additions.
I have a basic rocket design that I drew up that uses a single sheet of paper, which I've included in step 6 as a PDF.
Read on, and then go have some fun. (And hey, if you like this you should try out my Paper Stomp Jets!)
Step 1: Materials
This launcher design produces no waste, and should cost around $10.
For one launcher, you will need:
- One 10-foot length of 1/2-inch PVC
- One 1/2" 90-degree elbow (all fittings are of the slip variety)
- One 1/2" four-way fitting
- Two 1/2" end caps
- One 1" coupling
- One 1" by 1/2" bushing
- One 2-liter soda bottle cap
- Lots of 2-liter soda bottles
Other supplies you will need for this project:
- PVC cement
- Hot glue
- White glue
- Cotton balls
- Tape
- Sheets of 8 1/2" by 11" paper
- Lots of copies of the attached PDF rocket template
Step 2: Cut the PVC
From your 10-foot length of PVC, cut the following pieces:
- One 40" piece
- One 18" piece
- One 5" piece
- Two 12" pieces
- Three 11" pieces
Of all the pieces to be cut, accuracy is the most crucial on the three 11-inch pieces. These will be made into forming tubes which will be used to help make the actual rockets. Construction of the forming tubes is covered in step 5.
Step 3: Buld Basic Launcher Assembly
The photos should provide enough detail on how to construct the basic launcher assembly. Use PVC cement to put it all together.
The 12-inch pieces are the side supports that make the base. The 18-inch piece is the riser from which the rockets will launch. I used my palm sander to quickly knock off the sharp edge of the launch-end of the 18-inch piece of PVC.
The 1" coupling and the 1" by 1/2" bushing go together to make the bottle end of the launcher.
Step 4: Make the Bottle-end of the Launcher
2-liter bottles make great bladders for stomp rocket launchers because they're readily available and they're pretty durable. This set-up is especially nice because it allows you to quickly replace bottles when they've been completely worn out or cracked.
Begin by drilling a hole through a 2-liter bottle cap. This is easiest to do while the cap is screwed onto an old bottle.
I prefer to use hot glue to glue the bottle cap into the opening of the 1" coupling. Hot glue is quick, fills the gap between the bottle cap and coupling nicely, and it's only semi-permanent.
When the bottle cap itself begins to wear out and the threads are stripped, you can just grab it with a pair of pliers and yank it out to replace it with a new one.
Step 5: Make Rocket Forming Tubes
The three 11-inch pieces of PVC will be used to make three separate rocket forming tubes. These will help you make perfect rockets every time. It's nice to have a few on hand so more than one person can be working on a rocket at the same time.
You want the forming tubes to be slightly bigger than the tube that the rockets get launched from. This is accomplished by gluing a sheet of 8 1/2" by 11" paper around each forming tube. I used white glue and glued each sheet directly to the tube, and then to itself after rolling it on tight.
A piece of tape (I used electrical tape) was wrapped around one end of each paper-covered tube. This is to aid in the construction of the rocket, as detailed in the next step.
Step 6: Make Some Rockets
Print out and make plenty of copies of the attached PDF rocket template.
There are basic building instructions on the rocket template. Decorate and cut out areas as directed.
Roll the rocket body section onto forming tube, with the bottom of rocket (where the fin placement lines are located) just above the tape at the end of the forming tube. This creates an open space at the top of the tube, where the cotton balls will go.
Tape the body tube together, but NOT to the forming tube. Fold the fins and tape them in place on the fin placement lines. Place two cotton balls into the open area at the top of the paper tube, and cover with a couple of pieces of tape. Remove rocket from forming tube.
Step 7: Launch!
Before you launch your rockets, be sure to explain some safety rules to everyone involved so nobody gets shot in the eye.
After each launch, you will have to refill the bottle with air. I tell the kids to hold the top of the launch tube with their hand and blow through their hand to fill up the bottle. This way germ-passing is somewhat minimized.
I have made a total of six launchers, a couple of which were made with 45-degree-angled risers. These have been especially fun.
Be sure to post a comment and some photos if you make some stomp rockets of your own!
Second Prize in the
Dadcando Family Fun Contest
83 Comments
1 year ago
I see that you put cotton balls in the tip of the rocket. Why are there cotton balls? I am not sure of their purpose.
Reply 1 year ago
They add a little bit of weight to the nose and also help seal it up. You can probably skip them and just fold the top edges of the tube over the pvc form and add tape to seal up the nose area.
2 years ago
how you know
10 years ago on Introduction
to easy...
Reply 2 years ago
i think so but have you
lol first pic kid has crocs
Reply 2 years ago
not true at all in my opinion
2 years ago
this is so cool and i think i will be doing this rocket.
11 years ago on Introduction
Hmmmm. I wonder if it can be modded to break down. I'm science teacher with limited storage space.
Reply 3 years ago
I have made a somewhat modular one today. the pipe that runs from the bottle to the rocket launch end is one continuous pipe. I ground out the the 4 way splitter with my Dremel so that it can slide onto the main pipe. the stabilising arms are glued into the splitter as they should be. I have yet to attach a bottle as yet though as the parts I bought aren't correct for the job, so I'll try come up with a solution that allows the slip on stabilisation arms and the bottle. job for tomorrow morning. will let you know what I end up with
Reply 11 years ago on Introduction
If you find that the dry fit doesn't work, purchase a part called a union ($2.50 at Home Depot). It will provide a water tight screw-on connection between two sections. There are also adapters from slip-to-threaded that might work. Probably a lot cheaper, too.
I think the upright and the leg pieces could just be dry-fit together, so you could disassemble everything for storage.
Question 3 years ago
I made this with a group of students and we have found that we have NOT been able to find a 2 liter soda cap that will fit into the 1 by 1/2" bushing. Am I missing something here? Have cap sizes changed?
Answer 3 years ago
Oh, I'm sorry! I don't know if they have changed, but what I would do is take whatever soda bottle caps you have and find whatever pvc fittings are the closest match and go that route.
That's the nice thing about pvc; you can adapt sizes up or down fairly easily. I hope you're able to figure it out! Sorry I can't be more helpful - the 2 liter bottles I've seen lately appear to the same basic style that I used for this project.
4 years ago
I've made something like this a couple of years at a professional development, and wanted to do this with my students this coming year. So glad I came across your instructions, love the bottle cap idea.
5 years ago
It's perfect. I'm doing a science project in class and this is just what I'm looking for. Thank you :).
7 years ago on Introduction
I used your glued bottle cap on my project...thanks for the idea.
Step 14
https://www.instructables.com/id/Air-Trajectory-for...
Reply 5 years ago
I like this keep it up
wink wink!!!!!!!!!!!!!!!!!!!!!!!!!
I modified the bottle attachment end. I used what I had on hand already, plus a couple pieces that I got from Lowe's. The Transition Adapter fits snugly inside the neck of the 2-Liter bottle and you don't have to worry about any hot glue or bottle caps. (I did have to cement the Couplings so they wouldn't come apart.)
2.... 3/4" X 1/2" PVC Bushings
1.... 3/4" PVC Coupling
1... 1/2" CPVC Transition Adapter w/ male threads
1... 1/2" CPVC Transition Adapter w/ female threads
(I think I could've just used a 1/2" PVC Coupling in place of the first two items, though. I'll try that on my second one and see how it goes.)
Ooh, nice!
Looks like a good way to do this. Thank you for sharing this.
