Paracord Drink Bladder Tube Cover
Intro: Paracord Drink Bladder Tube Cover
So this is my first intructable so it will be great to hear what you all think. I have put this together as I wanted a convenient place to carry a good length of paracord on my rucksac when out and about and decided a cover for my drinks bladder tube would be a great option as it not only carries a single piece 24 foot long but provided protection for the tube and some degree of insulation.
Its worth noting that the tube for my bladder detaches from the bladder itself this therefore makes it easy to feed the tube in to the rucksac with the cover in place, if yours does not detach it ill be worth checking if the tube will fit through any holes you have in the bag with the paranoid cover in place.
STEP 1:
24 foot of paracord (this covered 17inches of tube)
Scissors (or some other way of cutting the cord))
A lighter or matches to melt the ends
2 elastic bands
Drink bladder tube
STEP 2:
STEP 3:
STEP 4:
Keep the weave tight by pushing the weave up towards the valve every now and then, as you start to get further in you will need to release some more cord from the bundles on each side.
Continue to do this until you have either used up all your cord or reached your desired length.
STEP 5:
The second end you will need to leave a little longer and tie a simple knot it in as close to the weave as you can, (I found that simply cutting and melting as usual did not create an adequate lock). Cut the cord after the knot and melt the end.
Now its time to fit your bladder in to your desired rucksac and get put and enjoy yourself.
Thanks for reading.
5 Comments
Gabeuse 10 years ago
Good idea to avoid the disgusting first sip caused by the sun heating the tube!
Soloman7 9 years ago
haha! I always dislike that first sip. ;)
Nice idea. :)
dan_w84 10 years ago
thanks, I am thinking that the black cord may absorb a fair bit of heat in the summer so may change to a lighter colour for this reason once its a bit warmer.
birdman732 10 years ago
curious youth 10 years ago
great job! this such a good idea thanks
