Patch a Truck Bench
Intro: Patch a Truck Bench
I just bought a used truck in great shape, except for a nasty hole in the bench seat. Thankfully, that's pretty easy to fix. Of course, this isn't for show cars, but a work truck doesn't need to be pretty; just functional.
STEP 1: Materials Needed
First, you need some material to to use as a patch. Denim is my favorite patch material, because it's strong, and it's easy to get. Everyone wears jeans, and they all wear out eventually. When they do, save them; they may have holes in the knees, but there's still plenty of good fabric there for patches. This patch came from the back of a leg from an old faded pair I stopped wearing months ago.
Just lay the pants over the damaged area, and cut around it. I like to leave about 2" of material past the edges of the hole on all sides. This allows some extra for the hem, plus it makes sure that when I sew it down, I'm sewing into good material, and not part that's about to fall apart. Next, make sure you have rounded corners. If you leave a sharp corner, it will tend to get caught on things, no matter how well you sew it down.
The other three things you will need are curved needles, ultra-heavy-duty thread, and some foam (I used a mattress topper). You will also need a sewing machine and regular thread. Oh, and you'll need a truck with a hole in the seat ;-)
STEP 2: Hem the Patch
Next, we're going to hem the patch on our sewing machine, before we sew it down to the truck.
Hemming is basically just folding over the edge and sewing it down. I like to use a zigzag stitch over the edge of the fabric, but you can hem with a straight stitch. Since it will be inside the bench, it's never going to fray.
Hemming around a curved corner is a little harder than ordinary hemming, especially with denim. Basically, when the folded fabric doesn't want to sit where it needs to, you lift the presser foot with the needle sunken into the fabric, but not in the hem (see second image). Then you re-fold the fabric hem so that it is where it should be, and drop the presser foot. This will cause a small 'gather', but you can just sew right over this. A rounded corner should have 3 or 4 of these.
After you've hemmed the entire patch, be sure to trim off all of the loose tails on both sides of the patch.
STEP 3: Stuff the Hole
The next task is to fill the hole in the foam. Foam is easy to get in many forms; I purchased a mattress pad for $11 at Family Dollar. You only need a small amount; the rest will be left over for a future project.
Cut small pieces and stuff them into the hole. You want to have it tightly packed at the bottom of the hole, but you don't want it bulging out at the top. The more it bulges at the top, the the tighter you'll need to sew the patch down. You also want to be sure that there aren't any sudden edges in your foam; I tapered the top layer's edge with scissors so that it was a smooth transition from the original foam to the added foam.
I actually spent a lot of time getting this 'just right'; once you've sewn down the patch, there's no way to fix the foam. I placed the patch over it, then ran my hand over it to make sure it was smooth, without any lumps. Take your time on this step.
STEP 4: Sew Down the Patch
Now it's time to practice your hand stitching. This step will take the longest. It took me about 40 minutes, but for those who don't hand sew much, expect an hour or two.
First, you want to prepare your needle & thread. I like to use a longer piece of thread so that I have to tie it off fewer times, but for first-timers, you may want a shorter piece. I would recommend cutting off about 5' of thread. Thread your needle onto it, then tie the two ends together (see the first image). Hand sewing is always done with the thread doubled over. You'll want to tie about 3 knots over the top of each other, making a very large knot. This is to prevent it from slipping through the fabric. Leave a half in or so after the knot; this is called the thread tail.
Next, you will need to start off the thread. I started from underneath the original fabric, so that the thread tail won't be visible. After starting it, you'll need to lay the patch onto the seat and get it situated how it will be. Start at the top, and work your way to the bottom. If there are any mistakes, they'll catch up to you at the end (you'll have a gather where there shouldn't be one), and it's better to have them out of view.
If you want to patch to last well, you'll want to make sure to have your stitches close together, but with a hemmed patch and extra-strong thread, they don't have to be closer than 1/5" or so.
STEP 5: All Done!
If you've made it this far, congratulations! If you've actually patched a seat using this method, please post a picture, I'd love to see how it turned out. Total time for my repair was about 2 1/2 hours.
After I was completely finished, I decided to go back and use some spray on fabric dye from Rust-oleum, called 'Fabric & Vinyl Flat'. It darkened it up a lot; perhaps too much.
10 Comments
ghettocottage 4 years ago
ykivity 10 years ago
Thanks!
bellinghammakerspace 11 years ago
Zibodiz 11 years ago
--shamelessly stolen from my hero, Red Green
kdf.inc1969 11 years ago
Let me know how it turns out if you decide to go for it :-)
pbates123 11 years ago
A couple of idea's first you might try the die on a patch of the material and check it against seat first. And if it's a good match treat the patch before installing it.
Then another idea more in the line of cosmetics. Recreate the stitch between the top piece of the seat and the side piece in your patch. It will look less out of place.
Add about a half inch to the top and bottom of the patch material. Invert the patch and place it across the seat on the other side of the vehicle and trace the line of the seam. This should closely approximate the curve on the torn side.
Cut the patch on this line. Place the left half on top of the right half as if you were folding the piece in half. The curve of the cut should match. Sew about one half inch in from the cut sewing the two pieces together. Open the piece up like a butter fly and you may wish to iron the piece open at this point. Sew a hem around the piece as shown in the instructable. Match up the patch with the seem and sew the patch over the torn area following the instructable.
Great idea wished I had thought of doing that in some of my vehicles.
As far as making an unneeded seam to imitate the seam that would have been there, that's a brilliant idea, and I just wish I had thought of it :-)
dreiseratops 11 years ago
Hell blue looks a heck of a lot better than yellow...
