Introduction: Pearl Bracelet Pattern - How to Make Wide Pink and White Pearl Bead Bracelets
About: Hi, guys!! I’m Daisy. I love putting beads together to make jewelry work; sharing jewelry designs. If you like jewelry and beads, you are in the right place. I’ll regularly update new jewelry tutorials about b…
Looking for pearl bracelet patterns? What about the following wide pink and white pearl bead bracelet? Follow me to see how to make this pearl bead bracelet.
Step 1: Supplies Needed in DIY the Wide Pink and White Pearl Bead Bracelets:
8mm Pink Round Pearl Beads
6mm Pink Round Pearl Beads
4mm White Round Pearl Beads
6mm Black Bicone Glass Beads
2mm Golden Seed Beads
Golden Spring Clasps
Golden Jump Rings
0.2mm White Fishing Wire
Stainless-Steel Scissor
Step 2: Make the First Part of the Pink and White Pearl Bead Bracelet
1st, cut a part of 0.2mm white fishing wire and thread it through a golden spring clasp. Then, thread 7 2mm golden seed beads to the two sides (as shown in the picture);
2nd, make some knots with the wires (as shown in the picture);
3rd, add an 8mm pink round pearl bead, 9 2mm golden seed beads, an 8mm pink round pearl bead, 9 2mm golden seed beads and an 8mm pink round pearl bead (as shown in the picture);
4th, add 7 more 8mm pink round pearl beads and 2mm golden seed beads. Then, refer to the 1st step and the 2nd step to make a loop and add a golden jump ring (as shown in the picture).
Step 3: Make the Second Part of the Pink and White Pearl Bead Bracelet
1st, cross the wire through the pink pearl bead (as shown in the picture);
2nd, add 9 2mm golden seed beads and cross the wire through the second pink pearl bead (as shown in the picture);
3rd, refer to the above steps to add more 2mm golden seed beads (as shown in the picture).
Step 4: Make the Third Part of the Pink and White Pearl Bead Bracelet
1st, cross the wire through the 8mm pink pearl bead and golden seed beads. Then, add a 6mm pink round pearl bead, a 2mm golden seed bead, a 4mm white round pearl bead, a 2mm golden seed bead and a 6mm pink round pearl bead. Cross the wire through the 8mm pink pearl bead and golden seed beads (as shown in the picture);2nd, refer to the above steps to make more such patterns (as shown in the picture);
3rd, cross the wire through the golden seed beads. Then, add a 6mm pink round pearl bead, a 2mm golden seed bead, a 4mm white round pearl bead, a 2mm golden seed bead and a 6mm pink round pearl bead (as shown in the picture);
4th, cross the wire through the golden seed beads. Then, add a 6mm black bicone glass bead and cross the wire through the golden seed beads (as shown in the picture);
5th, refer to the above steps to make more such patterns (as shown in the picture).
Step 5: Make the Rest Part of the Pink and White Pearl Bead Bracelet
1st, cross the wire through the pearl beads and golden seed beads. Then, add 4 2mm golden seed beads and 3 4mm white pearl beads (as shown in the picture);
2nd, cross the wire through the white pearl bead. Then, add 4 2mm golden seed beads and 3 4mm white pearl beads (as shown in the picture);
3rd, refer to the above steps to make more such patterns (as shown in the picture).
Step 6: Here Is the Final Look of the Wide Pink and White Pearl Bead Bracelet.
From the picture, we can see that the pink and white pearl bead bracelet is very elegant. The pattern is not very complicated. Once you gasp the first pattern, you may find it's easy to make the rest part. Try to make one if you like this pink and white pearl bead bracelet.
