Pen Gun (SUPER EASY!!)
Intro: Pen Gun (SUPER EASY!!)
This is a pen that launches its insides across the room! All you need is a clicky-pen. (Note: Not all clicky-pens work. You just have to try them with luck.)
STEP 1: Disassembley
Completely disassemble the pen. You will pull everything out of the tip of the pen, not the back. DO NOT THROW ANYTHING AWAY!!!
STEP 2: Reassembley
Reassemble the pen in the order shown in the picture below.I blended the colors of the parts in the picture together to show that they are inside the body.
STEP 3: Loading the Pen
Load the pen by pushing everything inside the pen to the back of the pen using the ink tube until you hear and feel a click. Slowly pull the ink tube out to see if the parts inside are stuck jamed down inside. Don't push so hard that you break it, obviously...
STEP 4: Take the Tube Out
If the parts stayed in like described in the previous step, take the ink tube out.
STEP 5: SHOOTING!!!
Shoot your pen by simply clicking it. DO NOT AIM AT FACE! That part that you found inside the pen is the part that will shoot across the room. the spring will fall out and onto the ground. KEEP TRACK OF THE PARTS! THEY ARE EXTREMELY HARD TO REPLACE! Use at your own risk. I am not responsible for how you use this gun. To reload, repeat steps 2-3. HAVE FUN!
noahw 16 years ago
- details a finished project with instruction (not just links to instructions)
- has clear images that you took of your project (web-found clip-art is not acceptable)
- uses proper spelling and grammar
- contains appropriate cautions or safety considerations
- does not violate someone else's copyright
- does not violate the Instructables terms of service
- is typically written about something you are very passionate about and want to share.
If this is a comment, a question, a small tip, or something that cannot truly be a finish project, please post it as a forum topic. If you are looking to start a collaboration, post a topic in the forums. Look here for tips on writing a great Instructable.
https://www.instructables.com/id/ELHMNOA69REUF10WM7/
So, it has been unpublished. Please do not republish until it has been corrected. When you republish, if everything is fixed, I'll remove this note. Multiple attempts to republish without correction will result in deletion.
