Pen Rose Triangle in 5 Easy Steps
Intro: Pen Rose Triangle in 5 Easy Steps
i chose the pen rose triangle because its pretty easy to draw and i learned how to make it in 7th grade. We were focusing on optical illusions and we learned about more illusions but i liked this one because drawing it is easy but the steps is hard to explain.
STEP 1: Step 1
first you draw a triangle (don't make it that big)
STEP 2: Step 2
Then, you draw three little lines that are connected to the sides of the triangle
STEP 3: Step 3
next you draw a longer line going the same direction from those same three little corners
STEP 4: Step 4
after you've done that, at the end of your line you need to make a v shape at the end of it
STEP 5: Step 5
finally you connect all the corners from the v shapes that you should've done then it should be made
3 Comments
Alywolf 7 years ago
Very simple to follow instructions, I think I will give it a go. Optical Illusions are awesome.
cameronblack1123 7 years ago
Swansong 7 years ago
That's neat :)
