Upcycled Parts Pencil Cup
Intro: Upcycled Parts Pencil Cup
These ideas come only from people that like keeping the junk* from taking apart electronic devices...
How can you make a pencil cup from a drill motor? Keep reading to find out!
*Your mom's point of view
STEP 1: What You'll Need:
What You'll Need:
A drill motor
A Hot Glue Gun (You can use other adhesives such as: Silicone RTV, Epoxy, Sugru, And More)
A Drill
About one meter (~1 yard) of rope, string, or wire
A flat and hard piece of any material you want (I used a ferrite, If you don't have one, It's your time to improvise!)
A Screw
A sharp metal object (A Phillips Screw-Driver can work)
The pens or pencils you want in the cup
STEP 2: Where Do You Want to Put It?
Choose a place where it will be comfortable for you to reach when you need a pencil,
I chose to place it under my Magnetic Pegboard.
After choosing the place, I marked a hole in the wood with a small Phillips Screwdriver.
STEP 3: Insert a Screw
Next, With my drill, I inserted the screw in the hole that I marked earlier
STEP 4: Take Apart the Motor
The motor is made out of two main parts (the Shaft and the Frame), I separated them by sliding them apart.
STEP 5: Hot Glue Time!
I hot-glued the ferrite to the bottom of the frame of the motor, This is to form a cup shape which won't let the pencils fall out through the bottom.
STEP 6: Make a Loop
After that, I made a loop with magnet wire and hot glued it to the the motor's frame
STEP 7: You're Done!
Place it on the screw. Don't forget to put your preferred pens or pencils inside! ;)
I might change the way that it hangs in the future, But for now, It's good enough...
STEP 8: Thanks for Watching!
I hope you enjoyed my Instructable, If you wan't to see more projects like this, Don't forget to visit my Instructables page and subscribe for more future projects!
If you find a that I made a mistake please point it out so I can fix it!
I'd also really appreciate it if you vote for me in the contests I've entered :)
If you build a one that is similar to what I built, Please post a picture in the comments to show everyone!
2 Comments
DIY Hacks and How Tos 8 years ago
Nice reuse of materials. It is always great to repurpose tools
BeachsideHank 8 years ago
You seem to be very organized, focused, and thrifty, all are good character traits in life, keep up the good work.
p.s. show this observation to mom!
