Pendant Lamp From Hanging Planter: Ikea Skurar Hack
Intro: Pendant Lamp From Hanging Planter: Ikea Skurar Hack
I was looking for a small pendant lamp and could not find the right design. Then I came across the Ikea Skurar Hanging Planter, standing upside down on the shelves.... Exactly what i wanted and the design only needed a hole to fit in the Hemma cord set.....
STEP 1: Tools and Ingredients
Tools:
marker
column-type drill
drills (I used 2mm and 3.5mm)
small metal cutter
rounded file
Ingredients:
1 Ikea Skurar Hanging Planter
1 Ikea Hemma Cord Set
1 Bulb
marker
column-type drill
small metal cutter
rounded file
Ingredients:
1 Bulb
STEP 2: First Steps...
Unscrew the plastic ring from the Hemma cord set and place it on the bottom of the Skurar hanging planter (or the top of the Skurar pendant lamp :-) ). Trace the inner circle with the marker.
Use the 2mm drill and the machine to drill small holes across the line.
STEP 3: A Little Further...
Then drill again using the 3.5mm drill, widening the gaps.
Use the metal cutters to cut the last circle completly.
STEP 4: Smoothhh....
Use the file to remove sharp edges and file until the Hemma cord set fits nicely.
STEP 5: Finished....
Well... almost finished still need to hang the lamp and put in a bulb. But you get the idea...
2 Comments
jm.beckers 9 years ago
Hi,
The wires in the wall had a difference in height.of 8cm.
I gave them a little support to hide this and level the lamps.
jm
scoochmaroo 12 years ago
