Pest Control Bag Tag
Intro: Pest Control Bag Tag
This project is a simple pest control upgrade for your loved backpacks.
The ultrasonic sound waves emitted is safe to humans and may offend pest such as rodents, mosquitoes and cockroaches.
Please see following instructions to see how the project was done.
STEP 1: The Circuit
The circuit is basically a 555 timer configured as astable multivibrator.
Frequency calculated based from R1, R2 and C1 values is around 43-kHz (above human threshold of 20kHz).
The output of 555 timer is fed to a piezoelectric buzzer creating the ultrasonic effect. The circuit is powered by two CR2032 button cells connected in series providing 6V supply.
STEP 2: Materials and Tools
Here are the tools and materials I used to complete this project:
Materials:
- 555 timer (IC1)
- 15k Ohms resistor (R2)
- 3.3k Ohms resistor (R1)
- 10nF mylar capacitor (C2 and C4)
- 1nF mylar capacitor (C1)
- 0.47uF electrolytic capacitor (C3)
- SPST Switch (SW1)
- Piezoelectric Buzzer (PS1)
- Key Chain (optional)
- Universal PCB
- Wires
- IC holders
- CR2032 Button cell and Holder
Tools:
Soldering Iron
Wire Stripper
Soldering lead
Hack saw (optional)
STEP 3: Dry Fit the Components
Assemble the parts to the universal PCB. The circuit layout is dry fitted to maximized space that allow it to look like a small back pack tag.
STEP 4: Assemble Components and Start Soldering
Solder the leads once installed to the PCB. Start with the small parts since it will be difficult for it to be soldered if the big parts comes first. Cut the excess leads of each component.
STEP 5: Wire the Circuit
This time wire the components based from the schematic given. Use of a smaller gauge wire is advisable. Cut any excess PCB using hacksaw.
STEP 6: Done!
Lastly put in the battery and add a key chain or any alike for it to be installed in a back pack.
Now the pest control back pack tag is done and ready for use.
Thanks and hope you enjoyed.
4 Comments
CheapLazyHobbyist 5 years ago
Empirically, it has no effect on mosquitoes. A 15kHz wave propagating in air is only good for annoying young kids (who can hear higher frequencies than adults).
I looked into this about a month ago. Please cite relevant research if you found otherwise.
Artuino 5 years ago
This device is working on the ultrasonic range (~43kHz). Haven't mentioned a 15kHz frequency in the instructions as you have mentioned.
Thorondor95 5 years ago
No offense, but using ultrasound to repel mosquitoes seems kinda gimmicky. Does this actually work? Enough to wear in the evening in Minnesota? Without bug spray?
Artuino 5 years ago
The ultrasonic effect seemed to annoy them since it emits sound at their audible range. also the effectiveness of the device depends on the area it could cover.. I have brought one of these before and label says it could cover a small room keeping mosquitoes at bay...Try and see for yourself I guess..
