Phone Charging Dock
Intro: Phone Charging Dock
a cherry wood charging station for your phone
STEP 1: Cuting the Wood
cut the wood to the dimensions that work for your phone. it doesn't have to be perfect or even anything specific just what works for you
STEP 2: Cating a Notch
i started by using a saw to make the gide line and then i used a chisel to smack the wood out of its plece
STEP 3: The Glue Up
this step is pretty straightforward, you know... just glue it up (and use a lot of clamps)
STEP 4: Making the Cable Insert
you can just finish the project now and you'll have a pretty nice phone stand but I decided to go a step further and make it a charging station i drilled a hole the same size of the cable and then made a channel for the cord
STEP 5: Sanding and Oiling
before I connect the cable I wanted to send the entire dock and put a finish of oil on it so it wouldn't touch the electronics
STEP 6: Glueing the Cable
i just used some hot glue in case i ever want to change the cable i also made some rubber feet using the hot glue so it won't slide around so much
