Photoshop: Classic Black and White Photo Techniques.
Intro: Photoshop: Classic Black and White Photo Techniques.
An alternative way to make a black and white photo in Photoshop, NOT just by clicking Mode -> Grayscale. Check inside for more detail.
STEP 1: The Original Photo
The original color photo was taken at Wat Sam Kor Temple, Chacheongsao, Thailand during my friend's ordination.
STEP 2: Simple B/W Method
Normally if you only choose Mode -> Grayscale, you can only get a Black and White image like this, the resulting color is too flat.
STEP 3: Alternative Way to Make a B/W Photo.
By using the alternative way, you can make a photo like this.
STEP 4: First: Change the Hue/Saturation Setting.
First: Choose Image -> Adjustment -> Hue/Saturation Setting, set it to -100%.
STEP 5: Set Black and White Points
Second: Choose Image -> Adjustment -> Levels, choose the "Set black point" and choose a dark area on your photo, see how the overall color changes. In this photo I choose the right-side of the forehead.
STEP 6: Set White Point
Same as previous step, Set the White Point. This time I choose the left arm of the other monk (right hand side of the photo).
STEP 7: Add Noise.
Add some noise from the Filter menu, I use about 25 in this image, and choose also "monochromatic" at the Add Noise dialog box.
STEP 8: Make a Border Selection.
Under the menu Select -> All, then Select -> Modify -> Border, this time I choose 50, but it depends on the size of your photo.
Then choose Select -> Feather, and this time I use 30, but it also depends on your image size.
STEP 9: Darken the Border
Choose Image -> Adjustment -> Curve, darken the border area.
STEP 10: Done.
The finished image is like a developed B/W using old film.
29 Comments
Metalog 12 years ago
phant0m_sp00f3ra 14 years ago
gsgenius 14 years ago
myliyana 14 years ago
blugyblug 15 years ago
wannabeharleyguy 15 years ago
misteright 16 years ago
Mouserz 16 years ago
Slavic Glitterati 16 years ago
gdub1973 16 years ago
inquisitive 16 years ago
pardonmyfreedom 17 years ago
pazu 16 years ago
velvet_skin 16 years ago
pazu 16 years ago
John Culbertson 17 years ago
chennes 17 years ago
Illidan 17 years ago
binnie 17 years ago
bzed 17 years ago
