Phun Rocket
Intro: Phun Rocket
Phun is a physics sandbox game where you can assemble objects and machines to see how they work in a perfect world. a simple project is a rocket.
STEP 1: Wall
the first and most important step is the walls. it is important to note that the thickness of the walls will determine the likelihood of a fuel leak.
it is possible to decrease the mass of the walls to increase the height it travels, but this also destabilizes the trajectory. this can be done by entering options>geometry and then moving the slider marked as density.
STEP 2: Cap
now any one know what went wrong there?
that's right the rocket didn't have anything holding it together. nor did it have any thing to direct the fuel downwards.
so we need to make a cap. the same rules about density and size apply to this that do to the walls.
next the cap must match the with of the walls exactly, and be perfectly centered. (this is more important the higher you go.)
we need to attach this to the walls using the fixate tool.
STEP 3: Fuel
fuel is the first real choice of the designer. there are three main schools of thought on fuels.
1st is liquid pressure fuels.
2nt is solid object spring fuels.
3rd is solid object pressure fuels.
liquid rockets are arguably the easiest to fuel. all that is needed is to make several objects inside the rocket and liquefy them in options>geometry.
spring rockets work by attaching springs to the walls of the rocket and to the fuels objects. by decreasing the target length the object will be forced out faster.
the last is the one I shall demonstrate. solid object fuels provide some interesting options. first is shape. wile the majority are circular rectangular has its advantages to. with rectangular fuel it is possible to direct 100% of the pressure downwards because the overlapping objects try to separate as quickly as possible. IE the rectangles go towards the long side.
for this instuctable I'll be using circles or ball depending on you preference.
now the fueling process can be long or short depending on how you do it. the longest way is to make hundreds of shapes with one of the tools. I don't recommend this. not only do you get inconsistent thrust but it takes forever. next is to clone one object. this still takes a wile but is more reliable than drawing. next is copy paist. this is fairly quick and reliable. the last is to use a chain with low breaking strength. this last one I like the most. it is the fastest solid ball option and can be duplicated easily.
STEP 4: Pressure Equilazation.
odds are if you build the rocket from the previous step it went a little wanky. and that's because the fuel wasn't evenly distributed. so how do you fix this. you let the fuel settle. "but won't it just shoot out the end" you ask. yes unless you cork it. and then in the options menu you set the destruction key for the cork.
hit the key and watch it fly.
14 Comments
admin 15 years ago
lucek 15 years ago
Derin 15 years ago
lucek 15 years ago
Articas 14 years ago
lucek 14 years ago
metalstorm99 15 years ago
lucek 15 years ago
alextricity 15 years ago
lucek 15 years ago
AnarchistAsian 15 years ago
lucek 15 years ago
instructors 15 years ago
Derin 15 years ago
