Pi Tape - Easily Measure the Diameter of Anything
13,261
83
63
Introduction: Pi Tape - Easily Measure the Diameter of Anything
About: Hello. My name's Arpan. At present, I'm an Aerospace engineering student. I love painting and making stuff.
Have you ever wanted to measure the diameter of a circular object and tried using a ruler to somehow find the diameter? Well, I have been in that situation many times. It's not always easy, especially if it's something like a hollow cylinder because you can't determine the midpoint to align your ruler.
That is where the Pi Tape comes in handy. All you need to do is wrap this tape around the object and it will directly give you the diameter!
It's extremely easy to make, so let's get making!!
Edit: I see a lot of people are confused that this is a standard tape measure. This is different from a standard tape measure. If you wrap a tape measure around an object, you'll be measuring it's circumference. This tape is designed to do the math for you and directly give you the diameter. So it has Pi hidden in it! Read ahead to find out!!
Chart paper
A ruler
Scissors
Pen/Marker
Transparent tape (optional)
Step 1: How It Works
Let's get the basics out of the way.
Suppose you want to measure the diameter of a cup. I'm using the Instructables cup here. We know that the diameter is the circle's largest chord and it always passes through the center of the circle. So in order to measure the diameter, you'll need to place your ruler on the top of the cup in such a way that it touches the center of the circle. But wait! The cup is hollow and you don't know where the center is. That's a problem.
To solve this problem, we can measure the circumference of the cup instead.
Because we know that the circumference of a circle is πD, we can obtain the diameter by dividing the circumference by π.
But π has a lot of digits after the decimal place (3.14159265358979...) and even just using 3.14 will make calculations hard if you don't have a calculator at that moment.
So we can make a tape with π divisions instead. Now when we divide it by π, we're just canceling out the π terms and the number left directly gives the diameter! Let's make it to find out if it works.
Step 2: Just Cut and Mark!
Cut out a long strip from a chart paper to make the tape. We need to make markings at every pi centimeters (or inches, it's your choice). Note that if your divisions are in cm then the diameter you obtain will also be in cm, and the same happens with inches.
You can use a ruler to make markings at 3.14cm, 6.28cm, and so on. But doing this will add an error with every division because you're approximating pi to two decimal places and multiplying a number to that approximation.
So, what we're going to do is take another strip of paper and make a marking at 3.14cm. Now we cut out this strip and use it as a template to make all the markings on our ruler.
Once all the markings are done, we will start writing numbers starting from 0. Don't label the first marking 1. Label it 0. We need some buffer before starting our number. You'll soon see the reason for doing this.
Step 3: Testing It
Now take a circular object whose diameter is known to you. This is to test if our pi tape is working.
Here I've taken the lid of a container whose diameter I know to be exactly 6.5 cm.
To find out it's diameter using the pi tape, just wrap it around the circumference and the point which coincides to the 0 reading is the diameter.
But wait. We see here that the diameter shown by our pi tape is around 6.6 to 6.7 cm. There's an error of around 2mm. Why so?
This is because when we wrap the tape around an object we're now adding the thickness of our tape on both sides of the object. So we're adding an error of 2×Thickness of the tape×pi. That's quite a lot of error even for a tape as thin as paper.
Fortunately, it's easy to solve this problem. All we need to do is make a marking before the 0 reading at the correct diameter value. In my case, I have to make a marking that coincides with 6.5cm. Now we have compensated for the thickness and can use this marking as our reading point. The number that coincides with this new point is the diameter of the object.
Step 4: We're Done!
As simple as that! Now you have your very own pi tape! I tried measuring the diameter of the Instructables cup and it comes out to be 8.6 cm. I don't have a Vernier caliper but I'm sure the folks at Instructables will know if my measurement is correct :p
Have fun making your own pi tape!
Pi Day Speed Challenge
Be the First to Share
    • Backyard Contest
      Backyard Contest
    • Stone Concrete Cement Contest
    • Meatless Challenge
      Meatless Challenge
    63 Comments
    frarugi87
    frarugi87
    Question 1 year ago
    Why are you using a 3.14cm sheet as a template instead of marking the multiples on the tape? I mean if you make a (let's say) 0.5mm error for each measurement, with the template you sum that error every time (so the second tick will have 1mm error, the third 1.5mm), while using the ruler and marking 3.14, 6.28, ... will "reset" the error at every tick
    Rainbow Cherry
    Rainbow Cherry
    1 year ago
    That's the same as a tape measure
    Arpan Mondal
    Arpan Mondal
    Reply 1 year ago
    This is also called OD (Outside Diameter) tape. It is different from a standard tape measure.
    Rainbow Cherry
    Rainbow Cherry
    Reply 1 year ago
    Oh k so it makes more sense or else I was wondering why we need that
    Rainbow Cherry
    Rainbow Cherry
    Reply 1 year ago
    Wait but why do we need to measure the diameter of something?
    Arpan Mondal
    Arpan Mondal
    Reply 1 year ago
    If you do a lot of DIY projects or you're an engineer, this will save a lot of time
    ManoelG3
    ManoelG3
    Reply 1 year ago
    If you don't know why do you need to measure the diametre of something, it's because you don't need to measure the diametre of something. So you don't need this tape. ;-)
    Rainbow Cherry
    Rainbow Cherry
    Reply 1 year ago
    Yeah I mean I do ALOT of DIY projects on my own but I never needed to measure the diameter of anything, and I needed the circumference but never the diameter good idea though
    DanniRedd
    DanniRedd
    Reply 1 year ago
    It is not to measure the diameter, it is quick way of finding the diameter of a cylinder
    mscaldwell888
    mscaldwell888
    Reply 1 year ago
    did you notice the cost of the pi tapes in your link? looked like $150 and up? This is a nice affordable solution. Good job Makestreme!
    Arpan Mondal
    Arpan Mondal
    Reply 1 year ago
    Yes, as I have mentioned in one of the comments, this is an OD tape and it already exists. But hardly anyone owns one and it doesn't hurt to know the math behind it and how to make one when needed :)
    kriemer
    kriemer
    1 year ago on Step 4
    I think another element of "error" in accuracy is that you hold the tape forming a spiral alling length to the measurement. If you added a tab to the zero point you would not have to do this and that issue would be further minimized.
    Brilliant idea!!! I've never seen it before (and I'm pretty old) it should be added as a scale on all tape measures.
    jmiketay
    jmiketay
    1 year ago
    I made mine with tic marks at every 1.57075 units and made a radius measure accurate(ish) to 4 decimal places.
    Arpan Mondal
    Arpan Mondal
    Reply 1 year ago
    That's great @jmiketay !
    Unfinished freedom
    Unfinished freedom
    1 year ago
    Thanks for this.:)
    Ignore the whining , crybaby mommy boys.;(
    Arpan Mondal
    Arpan Mondal
    Reply 1 year ago
    Haha thanks :D
