Raspberry Pi at Work: Serial Console Server
Intro: Raspberry Pi at Work: Serial Console Server
It is some time passed the last (modern) Millennium. We are now in the age of "Cloud Computing" yet there are still those who staff 24/7 Data Centers...... Where Inevitably"Legacy Systems" Lurk , running some forgotten but critical applications on hardware systems passed their prime.
These systems steadily hum along in the dark and dusty remote reaches of Data Centers HAUNTINGoperations staff; because no one truly knows the current status or utilization of such systems and even less is known about who set them up or how to support them in the event of a failure.... as no one gets many calls about them they are out of sight and out of mind..... UNTIL SOMETHING FAILS!!!!!!
WHAT HAPPENS IF THEY DO FAIL?
Such systems likely have no "Network Management" or Graphics cards.... in fact, this is in the case with Legacy UNIX systems the "Serial Console" is likely the only way to access or operate them in an emergency.
If youfind that you need to get give yourself or someone else (out of band) remote access to a "Legacy System" that has no modern “Network Management” capabilities consider using a Raspberry Pi.
Not only is it a neat toy but it may, in fact, fill a need you did not know you had.
Something else you may enjoy:
https://www.instructables.com/id/Pi-Power-Remote-Power-Management-with-Pi
STEP 1: PARTS
We will use a USB to TTL cable to both power and access the Pi as a headless Linux computer. The following steps will show how to setup “ARCH Linux” as a (Headless) “Pocket Serial Console Server” that can be used to access "Legacy Systems" anywhere in the Data Center.
Yes indeed, the Pi can be powered from just about any powered USB source...... so, you can use an (optional) battery pack or a powered USB port from any device or server to run a Pi.
ITEM LIST:
-Raspberry Pi
-Raspberry Pi Case
-USB to TTL Cable (Careful, some of these can have counterfeit chip sets and may not work correctly)
-USB to Serial Cable (Careful, some of these can have counterfeit chip sets and may not work correctly)
-SD Card (Careful, not all SD cards, “or revisions of prior working cards”, are Pi compatible.)
-Micro USB Wifi Adapter (Careful, not all adapters work with every Pi operating system; sometimes you need drivers)
-Null-Modem Serial Cable
http://www.amazon.com/s/ref=nb_sb_noss?url=search-alias%3Daps&field-keywords=raspberry+pi&rh=i%3Aaps%2Ck%3Araspberry+pi
http://www.amazon.com/Raspberry-Pi-Case-Enclosure-Black/dp/B00AZL16S4/ref=sr_1_3?s=pc&ie=UTF8&qid=1415975409&sr=1-3&keywords=raspberry+pi+case
Optional:
-External Smart Phone Battery Pack/Charger
STEP 2: LOAD YOUR OPERATING SYSTEM
Put the SD card in your Linux system; sorry, no instructions for Windows systems at this time.....
[[ PREP SD CARD]]
#You will need to be SUPER USER(root) to do this....
sudo -s
#ONE LINE FORMAT OF SD CARD (Careful, make sure this is the right device)
fdisk -l
fdisk -l /dev/mmcblk0
echo -e "p\no\np\nn\np\n1\n\n+100M\nt\nc\np\nn\np\n2\n\n\np\nw" | fdisk /dev/mmcblk0 #ONELINE
## SETUP FILESYSTEMS
fdisk -l
mkfs.vfat /dev/mmcblk0p1
mkdir -p /tmp/boot
mount /dev/mmcblk0p1 /tmp/boot
df -h
mkfs.ext4 /dev/mmcblk0p2
mkdir -p /tmp/root
mount /dev/mmcblk0p2 /tmp/root
df -h
[[ ARCHlinux: Raspberry Pi (Install OS) ]]
sudo -s
## GET ARCH LINUX OS FOR YOUR PI
mkdir -p ~/ARCHlinux
cd ~/ARCHlinux
wget http://archlinuxarm.org/os/ArchLinuxARM-rpi-latest.tar.gz
## COPY OS TO SD CARD
cd ~/ARCHlinux
gzip -dc ArchLinuxARM-rpi-latest.tar.gz | (cd /tmp/root; tar -xvf - )
df -h
(ls -al /tmp/root/boot; cp /tmp/root/boot/* /tmp/boot; rm -rf /tmp/root/boot/*; ls -al /tmp/root/boot) #ONELINE
ls -al /tmp/boot
df -h
umount /tmp/boot
umount /tmp/root
df -h
STEP 3: THE CASE
This is the Pi case.
STEP 4: LOAD THE CARD
Let's add the SD card with the OS.
STEP 5: PLUGIN THE USB TO TTL
This is the proper pin out for connecting my "USB to TTL" cable to the Pi...... Beware, as the wrong connections here could destroy something.
NOTE: The "colors" and functions for your cable may vary from mine; so, please refer to the documentation for your "USB to TTL" cable.... or risk it.... it's what I did. .....but as results will vary; perhaps, it is best use a multimeter to check for such things as power. Of course, my multimeter battery was dead at the time so I just went for it. ;)
STEP 6: MAKE SOME HOLES
I drilled a hole in the back of the case; because, I thought it looked nice and it was near the GPIO pins..... tied the inside and use electrical tape on the outside to make it look nice..... and it stops the wire from sliding in or being ripped out.
STEP 7: CLOSE
Closed it up.
STEP 8: HEADLESS
OMG, It's headless!!!
Once we close up our Pi, we can both power and access it via the USB end of the USB to TTL cable..... let's hope we wired it correctly!
#BOOT IT
Insert the SD card into the Raspberry Pi and use the serial console from the USB to TTL while plugged in to your LINUX system. The default root password is 'root'.
[[ SERIAL CONSOLE (to Pi) ]]
use your favourite serialterminal command while your have your Pi plugged into you Linux System via USB.
http://www.computerhope.com/unix/ucu.htm
http://www.gnu.org/software/screen/manual/screen.html
[root@localhost ]# dmesg | grep -i tty
[ 0.000000] console [tty0] enabled
[ 19.385214] Bluetooth: RFCOMM TTY layer initialized
[37694.944976] usb 2-1.2: pl2303 converter now attached to ttyUSB0
[root@localhost ]#
#ATTACH TO (Pi) SERIAL CONSOLE FROM LINUX
dmesg | grep -i tty
sudo cu -l /dev/ttyUSB0 -s 115200
sudo screen /dev/ttyUSB0 115200
#NOTE: RECORD MAC ADDRESS (we are going to need this later)
ifconfig -a
poweroff
[root@alarmpi ~]# ifconfig -a | grep -i ether
eth0: flags=4099 mtu 1500 ether c8:27:cb:b0:76:89 txqueuelen 1000 (Ethernet)
wlan0: flags=4098 mtu 1500 ether 00:28:2f:38:9c:88 txqueuelen 1000 (Ethernet)
[root@alarmpi ~]#
#NOTE: Yes the Mac Address can also sometimes be found printed on the device.... such as on the USB Wifi Adapter..... it was just as easy to do it from here as we had to "test" boot it.
STEP 9: Wait, Can I Get to the "Serial Console" of My Pi From Windows?
Yes you can, you only need to install something like "Putty" and add the correct drivers for the chip set in your "USB to TTL" cable......
#As I plug in the USB end of the "USB to TTL" cable into my Linux system and run a few commands it turns out my adapter is using a "Prolific Technology, Inc. PL2303 Chip".
[oem@localhost ]$ dmesg | grep -i detec
[68930.101474] pl2303 2-1.2:1.0: pl2303 converter detected
[oem@localhost ]$
[oem@localhost ]$ lsusb
Bus 002 Device 004: ID 0a5c:5800 Broadcom Corp. BCM5880 Secure Applications Processor
Bus 002 Device 003: ID 8087:07da Intel Corp.
Bus 002 Device 014: ID 045e:0745 Microsoft Corp. Nano Transceiver v1.0 for Bluetooth
Bus 002 Device 015: ID 067b:2303 Prolific Technology, Inc. PL2303 Serial Port
Bus 002 Device 002: ID 8087:0024 Intel Corp. Integrated Rate Matching Hub
Bus 002 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
Bus 001 Device 004: ID 1bcf:2804 Sunplus Innovation Technology Inc.
Bus 001 Device 003: ID 413c:8187 Dell Computer Corp. DW375 Bluetooth Module
Bus 001 Device 002: ID 8087:0024 Intel Corp. Integrated Rate Matching Hub
Bus 001 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
[oem@localhost ]$
#DOWNLOAD AND INSTALL THE DRIVERS FOR THE WINDOWS SYSTEM
http://www.prolific.com.tw/us/showproduct.aspx?p_id=225&pcid=41
#DOWNLAND AND INSTALL PUTTY FOR THE WINDOWS SYSTEM
http://www.chiark.greenend.org.uk/~sgtatham/putty/download.html
#FIND THE COM PORT ON THE WINDOWS
You can click around in the "Device Manager".....
mmc devmgmt.msc
.......or just use the command line querying the "Windows Registry".
reg query HKLM\HARDWARE\DEVICEMAP\SERIALCOMM | find "REG"
#USE PUTTY TO OPEN A SERIAL CONNECTION TO THE PI
C:\>reg query HKLM\HARDWARE\DEVICEMAP\SERIALCOMM | find "REG"
\Device\ProlificSerial0 REG_SZ COM4
C:\>
putty -serial com4 -sercfg 115200,8,n,1,n
#NOTE: It is basically the same as with the "cu" command on Linux.
STEP 10: GOT DRIVERS?
NO DRIVERS?
As it turns out the ARCH Linux install did not (by default) have the drivers needed for the Micro USB WIFI Adapter I have. (Edimax EW-7811Un) ...but it turned out to be a popular Realtek chip set so I install the drivers by using the wired (Ethernet) connection on the Pi while attaching it to my wired network...... This time I used the optional USB battery pack...
#NOTE: It was online for over 3 hours as played around shortly after I got the wireless network setup and it seemed to only have used 3/4 of the battery; not bad. ;)
[root@alarmpi ~]# lsusb
Bus 001 Device 004: ID 7392:7811 Edimax Technology Co., Ltd EW-7811Un 802.11n Wireless Adapter [Realtek RTL8188CUS]
Bus 001 Device 003: ID 0424:ec00 Standard Microsystems Corp. SMSC9512/9514 Fast Ethernet Adapter
Bus 001 Device 002: ID 0424:9512 Standard Microsystems Corp. SMC9512/9514 USB Hub Bus 001 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
[root@alarmpi ~]#
STEP 11: WIRE IT UP
If your wireless router has a powered USB port (as seen here) the Pi can run on your network just as it is intended to do in the Data Center attached to a server's USB port..... perhaps I will leave a Pi on the network as a small server....... (I did so) perhaps more on this some other time. ;)
STEP 12: (DUDE) WHERE'S MY Pi?
After you get it connected to the network you need to access it and if your home router is working correctly it will give the Pi an IP address and add the default host name "alarmpi" to DNS.
You can simply access it from your Linux system via the name:
ssh root@alarmpi
If not, no worries, as we can use the Mac Address to find the IP on the network using "ping" and "arp"; this works if you are on a computer that shares the same broadcast domain as the Pi.... most at home wireless routers should allow this.
http://en.wikipedia.org/wiki/Broadcast_domain
[[ FIND PI ON NETWORK ]]
Remember that Mac Address info we saved; we are going to need it now....
##FROM YOUR LINUX SYSTEM YOU CAN RUN THIS TO LOCATE THE PI VIA THE MACADDR
FIRST_3_OCTS = IP: 8 bits (octet) [[ #1. #2 . #3 . #4]]
YOUR_NIC = Your "Network Interface" in the same network as the Pi
MACADDR = the "Mac Address" of your Pi
for i in $(seq 254); do ping -c 1 {FIRST_3_OCTS}.$i -W 2 -I {YOUR_NIC} > /dev/null 2>&1; arp -a | grep -i "{MACADDR}" && break; done #ONELINE
#NOTE: Adjust wait time (-W 2) higher if you do not find your PI.
#EXAMPLE
for i in $(seq 254); do ping -c 1 192.168.0.$i -W 2 -I wlp2s0 > /dev/null 2>&1; arp -a | grep -i "00:28:2f:38:9c:88" && break; done #ONELINE
#NOTE: You can watch the progression in another terminal; else, grab a snack.
while :; do sleep 2; ps -ef | grep -i ping; done
Depending on how slow your network connection is, you will soon have the IP address for your Pi displayed when the command completes.
alarmpi (192.168.0.141) at 00:28:2f:38:9c:88 [ether] on wlp2s0
You can now use the IP address to login to your Pi:
ssh root@192.168.0.141
STEP 13: PACMAN?
Now that we have access to the Pi we need to initialize the ARCH Linux package manager......
https://wiki.archlinux.org/index.php/pacman-key
[[ SETUP PACMAN / UPDATE THE PI]]
#Initializing the keyring
nohup pacman-key --init &
time while (ps -ef | grep -iv grep | grep -iw pacman-key); do echo LOOP; (ls -R / > /dev/null 2>&1 &); sleep 5; done #ONELINE
jobs
#UPDATE Pi, reboot
(echo y; echo y) | pacman -Syu && reboot
After reboot we should have complete access to the ARCH Linux package repository; thus, we can find a install our drivers.
STEP 14: ARCH LINUX?
It many seem like a lot of work but ARCH Linux is a nice Linux Distro for the Pi as you install it only once and never need to do any upgrades.
Arch Linux uses a "rolling release" system which allows one-time installation and perpetual software upgrades. It is not generally necessary to reinstall or upgrade your Arch Linux system from one "version" to the next. By issuing one command, an Arch system is kept up-to-date and on the bleeding edge.
https://www.archlinux.org/about/
Besides this, it is very well documented and supported by an active community.
STEP 15: Pi WIFI (WPA/WPA-EAP)
Now let us get the WiFi setup so we can access our Pi on over the air.
[[ ARCH Linux WIFI (EdiMAX) / Raspberry Pi ]]
## INSTALL NIC DRIVER/WIFI SOFTWARE
#Update the OS and reboot if we have not already done so
echo y | pacman -Syu
reboot
#INSTALL THE DRIVER AND WFI TOOLS
echo y | pacman -Sy wireless_tools
echo y | pacman -Sy iw
echo y | pacman -Sy wpa_supplicant
echo y | pacman -Sy wpa_actiond
(echo; echo y) | pacman -Sy dkms-8192cu
## TEST DRIVER
lsusb
dmesg | grep -i driver
dmesg | grep -i interface
dmesg | grep firmware
dmesg | grep iwlwifi
lsmod
modprobe 8192cu
lsmod
## TEST DEVICE
ip link
ip link set wlan0 up
#OR
ip link set dev wlan0 up
#OR
ifconfig -a
ifconfig wlan0 up
#now
iwlist wlan0 scan
#Here you should see some broadcasting SSID(s) around you..
## MAKE HASH FOR WPA
wpa_passphrase HOME-SSID
#TYPE PASSWORD IN BLANK SCREEN (STIN)
#OUTPUT
network={
ssid="HOME-SSID"
#psk="fjfjdifjdf"
psk=5049231d192d9273cadb686299dabed1481ee984dcf28a3cb3679659476cdaf4
#SAVE THE PSK
## MAKE HASH FOR WPA-EAP
echo y | pacman -Sy openssl
pkgfile -s iconv
echo y | pacman -Sy glibc
echo -n YOUR_DOMAIN_PASSWORD | iconv -t utf16le | openssl md4
#OUTPUT
(stdin)= a949b4053abaf36398f442fb2286e426
password=hash:ADD_YOUR_HASH_HERE
#SAVE LIKE SO
password=hash:a949b4053abaf36398f442fb2286e426
## SETUP WPA
#Make a test WPA supplicant file.
vi wpa.conf
fast_reauth=0
ap_scan=1
network={
id_str="HOME"
proto=RSN
scan_ssid=1
key_mgmt=WPA-PSK
pairwise=CCMP TKIP
group=CCMP TKIP
ssid="HOME-SSID"
psk=a0b1cd4fe9c7be0c633535dec0b50305381a985458dc0fa9b53f3946ca988c78
network={
id_str="WORK"
ssid="CORP-SSID"
scan_ssid=1
key_mgmt=WPA-EAP
eap=PEAP
pairwise=CCMP TKIP
group=CCMP TKIP
# authentification info
identity="YOUR-DOMAIN-ID"
phase1="peaplabel=0"
phase1="auth=MSCHAPV2"
#EOF
## TEST_CONFIG
ifconfig wlan0 up
wpa_supplicant -Dwext -i wlan0 -c wpa.conf
#[GOOD OUTPUT]
wlan0: Trying to associate with 35:c8:04:b1:2g:10 (SSID='HOME-SSID' freq=2412 MHz)
wlan0: Association request to the driver failed
wlan0: Associated with 35:c8:04:[ 1209.286850] IPv6: ADDRCONF(NETDEV_CHANGE): wlan0: link becomes ready
wlan0: WPA: Key negotiation completed with 35:c8:04:b1:2g:10 [PTK=CCMP GTK=TKIP]
wlan0: CTRL-EVENT-CONNECTED - Connection to 35:c8:04:b1:2g:10 completed [id=0 id_str=]
# TYPE "ctrl-C"
## MANUAL RUN
#We now copy the working config over to the correct location....
cp /etc/wpa_supplicant/wpa_supplicant.conf /etc/wpa_supplicant/wpa_supplicant.conf-org
cp wpa.conf /etc/wpa_supplicant/wpa_supplicant.conf
#As we have a tested WPA config we can skip the test below....
wpa_supplicant -B -Dwext -i wlan0 -c /etc/wpa_supplicant/wpa_supplicant.conf
iwconfig
ifconfig
dhcpcd wlan0
ifconfig
nslookup cnn.com
telnet google.com 80
get /
#Run Updates
(echo y; echo y) | pacman -Syyu
## AUTO RUN WIFI(WPA) AT BOOT [systemctl]
#In ARCH Linux the Wifi Service is not setup be default we will need to do that now.
vi /etc/systemd/system/network-wireless@.service
[Unit]
Description=Wireless network connectivity (%i)
Wants=network.target
Before=network.target
BindsTo=sys-subsystem-net-devices-%i.device
After=sys-subsystem-net-devices-%i.device
[Service]
Type=oneshot
RemainAfterExit=yes
ExecStart=/usr/bin/ip link set dev wlan0 up
ExecStart=/usr/bin/wpa_supplicant -B -Dwext -i wlan0 -c /etc/wpa_supplicant/wpa_supplicant.conf
ExecStart=/usr/bin/dhcpcd wlan0
ExecStop=/usr/bin/ip link set dev wlan0 down
[Install]
WantedBy=multi-user.target
#EOF
## INIT SERVICE (AFTER EVERY EDIT)
systemctl enable network-wireless@wlan0.service
systemctl start network-wireless@wlan0.service
[[ DONE WITH THE OS/WIFI SETUP! ]]
As we are done with the wifi setup... we can remove the Ethernet cable and use the wifi from now on....
STEP 16: SERIAL CONNECTION
We now have a working headless Pi available over the wifi network; so, we can just plug it in and use it anywhere. Now we can add the USB to serial adapter and a Null Modem cable so we can use this Pi as a Serial Console Server.
[[ ADD SERIAL CONNECTION SOFTWARE TO THE Pi ]]
#We will need to add the serial control software, like so:
echo -y | pacman -Sy pkgfile
pacman -Sy pkgfile
pkgfile --update
pkgfile -s cu
echo y | pacman -Sy uucp
#ONELINE
dmesg | grep tty
ls -l /dev/ttyUSB0
[[ THE CONNECTION ]]
Remotely Accessing the PI with the business end of the NULL-Modem attached to a server's serial console and you've got yourself a Pocket Sized Serial Console server that you can take with you anywhere or ship out to remote sites.
## USE SERIAL CONSOLE
cu -l /dev/ttyUSB0 -s 19200
#QUIT Serial session: ~.
#Bit rates commonly supported include 75, 110, 300, 1200, 2400, 4800, 9600, 19200, 38400, 57600 and 115200
cu -l /dev/ttyUSB0 -s 9600
#One of these bit rate will likely for for you; you just need to type "~." to stop the serial session.
STEP 17: REFERENCE CONFIGURATIONS
These are some examples of "Serial Null Modem" configurations using adapters provided by various manufactures; while it is best to use a true Null-Modem cable sometimes you will find that a combination of (Rj45 to DB9/DB25) adapters also works.
STEP 18: IN THE DATA CENTER
Example of a serial connection to a server's serial console in the Data Center...
STEP 19: Windows Control Via Serial
Did you know that control via Serial Console Connections are not just limited to UNIX/LINUX? A serial control connection can also be use on Windows Servers as well.......
Someone only needs to set the Windows "Boot Parameters" to "Enable EMS Redirection" and windows will respond to a serial connection.
Yes, those "Legacy Windows Servers" without Network Management Consoles can also talk to the Pi Serial Console Server.;)
The following Bootcfg command enables EMS console redirection on the first boot entry in the list. It sets the port for COM2 and sets the transmission rate to 115,200 kilobits per second (Kbps). So you can also use the Pi for out-of-band administration windows servers via the serial port.
bootcfg /ems ON /port COM2 /baud 115200 /id 1
http://en.wikipedia.org/wiki/Emergency_Management_Services
STEP 20: CREDITS
[[ Intro Image Info ]]
I modified an image I found that claimed to be "Attribution-NonCommercial-ShareAlike 2.0 Generic
(CC BY-NC-SA 2.0)" Licence...
Data centre panorama by: ~Bob~West~
http://www.photoree.com/photos/permalink/9993530-38176485@N08
3 Comments
Bacon Fat 8 years ago
Wow arch and pi. nice, I would have just pput an old windoze box next to with a serical to usb and installed team viewer.
!nstructable 9 years ago
Yes, it is so 90's.... sadly, not everyone is doing "Cloud".
zpekenneth 9 years ago
Pretty elite instructable, takes me back to the 90s! Thanks for
sharing this, Mr. !nstructable. Shameless plug of another serial
wrangling solution you can enjoy "with your cereal" for light morning
reading, see this software that also manages legacy IT assets, and
serves as a bridge to extend product life, provides power management to
non-OOBI devices, and more:
http://www.zpesystems.com/blog/free-yourself-from-...
Cheers!
Ken
