Introduction: Piano Glove - Scratch Makey Makey
Piano Glove
1) A glove
2) A well function computer
3) Makey Makey
4) Tin foil (as more as possible)
5)A stand, could be a plate to hold everything
6)Thin wires
Step 1: Codes
1)To start code
a)Go to https://scratch.mit.edu, sign in, and start a new project name Piano glove
b)Go to add extension find Makey Makey
c)Drag when_ key pressed(Could be any key if you favor to)
d)Decide 8 keys you will need, and copy the code when there are 8 blocks and stop then enter the keys you decided.
e) go to sounds library and find Piano notes: C,D,E,F,G,A,B,C. If there are no notes you want, you cloud always go to YouTube to find notes you like
f)insert them, done! You finish the coding part
Step 2: Physical Components
1) Get Tin foil, cut into 8 parts, paste on a plastic plate
2)use wires to connect Makey Makey to the right spots, connect both Makey Makey and tin foils
3)use Thin wires to roll up on the glove, extend parts connect to the earth on Makey Makey
Done! You have made a simple glove piano by yourself.
