Introduction: Pile of Equations
You need to get everything that you need to be able to bake the special "Math Cake"
You need to get the color or flavor of frosting that you need and you need to get all of the ingredients.
Step 1: How to Make the Cake
How to bake:
Step 1: All you need is 1 cup of water, 1/2 cup of vegetable oil and 3 eggs.
Step 2: Set the oven to 350 degrees. Coat the bottom of the pan with non-stick cooking spray.
Step 3: Combine cake mix, water, oil and eggs in a large bowl, mix until smooth. Beat with electric mixer on medium speed for 2 minutes. Pour batter into pan.
Step 4: Bake at 350 degrees, follow the bake times on the box. When toothpick inserted in the center comes out clean and not wet from the cake batter that means the cake is done. Cool 10-15 minutes before removing from pan. When completely cooled then frost. When done frosting then store loosley covered in a cool area.
Step 2: Finishing Touches
Once you have completed frosting you can put the decorations on top and if you are doing a math cake then you can take a different colored frosting and put different math equations on top of the cake.
