Pinball Machine at Boca Bearings
Intro: Pinball Machine at Boca Bearings
Congratulations, you have decided to make a Pinball machine
based on the Boca Bearing Design! As an intern at Boca Bearings, I created this pinball machine. Now before you get into this project an important thing to note is that our machine has a material cost of about $7-800, pinball electronics are expensive. However, this cost can be cut down to $300-500 if you were to modify our design, use un-sanded plywood, and have the only electronics be the ball return, flippers, and launch system while using 3d printed parts to make obstacles on the playfield.
The first step in making the pinball machine is to make the box to house all the electronics and the playfield. To do this the first step is to set up your sawhorses, 2 sheets of plywood, and draw out your cuts as shown in the schematics below. One modification you may want to make to the design is to add an inch on each side to the bottom panel so that the sides are sitting on top of it instead of having the bottom nested between the sides.
Note: You need two side panels, and the left and right side are identical.
You may have noticed there is no piece specked out for the top flat 10.25in the surface on the sides of the box, you will have to take a moment to get some measurements and assess the dimensions for that piece. With that said you do not want to add that part till later to give a better working clearance. Once you have all these parts cut out, it is time to assemble. For assembling the box, you have two options, the first if you have a finished nailer, I highly recommend using that with a little wood glue to assemble the box it will make your process much quicker. If you do not have a finish nailer you can use a drill and finish screws to assemble the pieces, make sure you drill a pilot hole for every screw on you will have issues with the plywood delaminating.
Now that you have the box taken care of it is time to design your playfield. This is where you can take your creativity to the max. Shown below is one example of how to layout the playfield with the five medium holes being for the spinning pillars and the 3 large ones being for the three-pop bumper. Now you do not need to hold true to this design, even I changed it significantly as I built it. The main things you need to be certain of are that your tolerances are high enough that a ball won't just get stuck in play, so no gaps less than 1in. You may also notice a bunch of slots in the playfield, these are not necessary unless you want to add rollover switches for a scoreboard which is no simple feat. While an attempt was made to implement a scoreboard with this project there was a large problem where the wires used for signaling were not insulated, and with such a large quantity of them crossing there was a high level of electrical noise which led to false signals. This could potentially be fixed with the use of insolated wires, but this has not been tested. Another thing to note is the large slot in the bottom of the playfield that was designed for a 3d printed ball return system. This return system was a failure and the decision was made to go with an off-the-shelf solution, this slot will not inhibit the implementation of the off-the-shelf return system though it is not strictly necessary for a functional system.
Once you have the field done it is time to add your mechanism to your playfield stays steady in the box. For this, you will need a 2x4 and a 21x1in dowel rod. Your first step is to cut two 4in long pieces and drill a 1inch hole through them about 1.5in up. This hole is going to be so you can fit a dowel rod through that is going to be your pivot arm. It may be a tight fit but sand the hole until you can fit the dowl through. Once those are affixed your next step is going to be to attach it to the playfield you want to make sure this piece is centered and looks something like the picture below.
Once this is affixed you now need to take some more of that two my four and make the brackets for the inside of the box. You will need to stack two of the below brackets on each side of the box, this will allow the dowel to sit in them and pivot so you can raise the board to work beneath it. You will also need to put some boards on the front inner sides of the box in a place that will not interfere with any of the other components but will leave the playfield at an angle of approximately 6.5degrees.
The inside of your box should look something like the above picture.
Once you are this far now is the time to paint your box if you so choose, we decided to go with a black stain and a gloss varnish on the box but left the playfield natural wood. We also added some 1in angled aluminum trim and below is how it turned out.
At this time you may want to add some handles to the box to make it easier to move, we went with some 4in black ones but you can use whatever strikes your fancy.
Now you are ready to start the electrical your first step is to install the fused switch plug in the back and the 24v power supply. The diagram below shows how you wire up the plug and you want to wire the input voltage for the power supply to the output voltage of the socket. If you are going to add LED lights that have a controller that runs off of 120v AC then I highly suggest that you add a 4 port connector into these lines as well that way you can easily break wires out and solder them to the controller inside the box.
Next, you will want to find someplace on the inside of your box for your relay panel, you will need one relay for each electronic component that needs to be actuated. For our system, we used 13 relays but yours may be higher or lower depending on how you lay it out. There are plenty of tutorials online that explain how to wire relays up much better than I can write here so if you do not know how to deal with relays you should refer to them.
Once you are this far it is now time to add all your components to your playboard. If you are following along one component of the playboard that was designed successfully in-house at Boca Bearings was the spinning pillars, this adds an element of movement and allows for a unique in-game obstacle. A picture of it is shown below.
The final version was designed in such a way that it can be entirely printed on a Prusa MK3 except for the motor and the ten R16-ZZC PS2 bearings that you can find at our website: https://www.bocabearings.com/products/r16-zzc-ps2... . The files for this and can be found on my grabcad account linked here: https://www.bocabearings.com/products/r16-zzc-ps2... One thing to note though is that the tolerances are a little fussy with this assembly so you will need to play around a little with your settings to find what works best for your printer.
Another part that you may want to 3d Print is the ball launching mechanism shown below. Now, full disclosure this system is not perfect and is more underpowered than initially expected, but it functions properly with both plastic and Si3N4 bearings. The drawback to this is twofold, plastic balls are cheap, but they create a wicked fast game and will not always trigger something that they hit. The Si3N4 are light enough that they will make it up the play ramp, yet heavy enough that they will cause a more normal play speed and actuation, however, they are quite expensive at around $80 a ball. But given that for the purposes of this build and the average home user plastic balls make for a plenty fun game, and the files for this are also up on the grabcad linked above.
There are three other parts in the grabcad file you may find useful as well, those being the flippers, cover for the slingshots, and the top half of the ball return system. The reason you may want to use the top half of the ball return system is as a guide for your ball to be loaded into the launcher, there are other ways to do this, but this is the one we used.
Once you have all your obstacles and other parts attached it is now time to add your guide rails for your launch and return system as well as the buffer around the edge of your playfield to keep your balls from rolling where they should not. For this, we used scrap pieces of 3/4in plywood stacked to a thickness of 1.5in. This will take a little bit of fine-tuning to your individual field, do not be afraid to add or modify pieces so that the ball runs smoothly through the playfield. Ours ended up looking like the picture below.
Once you have all your pieces installed its time to wire everything up, remember to make sure you have the machine unplugged from the wall as messing with these components with the system powered on could potentially result in serious injury. One thing that we found useful was to make use of a short lead with a spade connector attached to your component followed up with a longer bridging wire in between, this way if you mess up a connection it is super easy to swap with the proper lead. If you have any buttons that use 5v or 12v LEDs make sure you step down the voltage using a Buck Converter, otherwise you will end up blowing out your lights. Another tip is to use 4 port connectors to split out your power and ground coming out of your power supply, this will make your wiring a lot easier.
Congratulations! Now that your wiring is sorted out your pinball machine is ready to test. A final thing to note is that if you want to make to free standing you can use threaded iron pipe like we did for the legs or leave it flat bottomed and set it up on your workbench. However, you chose to set up your machine remember you have accomplished something big and it is now time for you to enjoy the fruits of your labor and have fun with it!
STEP 1: Draw Out Your Cuts
the first step in making the pinball machine is to make the box to house all the electronics and the playfield. To do this the first step is to set up your sawhorses, 2 sheets of plywood, and draw out your cuts as shown in the schematics below. One modification you may want to make to the design is to add an inch on each side to the bottom panel so that the sides are sitting on top of it instead of having the bottom nested between the sides.
STEP 2: Designing the Playfield
STEP 3: Adding Mechanism to Playfield
Once
you have the field done it is time to add your mechanism to your playfield stays steady in the box. For this, you will need a 2x4 and a 21x1in dowel rod. Your first step is to cut two 4in long pieces and drill a 1in hole through them about 1.5in up. This hole is going to be so you can fit a dowel rod through that is going to be your pivot arm. It may be a tight fit but sand the hole until you can fit the dowl through. Once those are affixed your next step is going to be to attach it to the playfield you want to make sure this piece is centered and looks something like the picture below.
STEP 4: Brackets for the Inside of the Box
two by four and make the brackets for the inside of the box. You will need to stack two of the below brackets on each side of the box, this will allow the dowel to sit in them and pivot so you can raise the board to work beneath it. You will also need to put some boards on the front inner sides of the box in a place that will not interfere with any of the other components but will leave the playfield at an angle of approximately 6.5degrees.
STEP 5: Painting the Box
picture.
STEP 6: Start the Electrical Part
STEP 7: Relays
STEP 8: Components
components to your playboard. If you are following along one component of the playing board that was designed successfully in-house at Boca Bearings was the spinning pillars, this adds an element of movement and allows for a unique in-game obstacle. A picture of it is shown here.
STEP 9: Ball Launching Mechanism
The final version was designed in such a way that if can be
STEP 10: Guide Rails
is now time to add your guide rails for your launch and return system as well as the buffer around the edge of your playfield to keep your balls from rolling where they should not. For this we used scrap pieces of 3/4in plywood stacked to a thickness of 1.5in. This will take a little bit of fine-tuning to your individual field, do not be afraid to add or modify pieces so that the ball runs smoothly through the playfield. Ours ended up looking like the picture below.
STEP 11: Finished
