Plaited Braid With Beads
Intro: Plaited Braid With Beads
Plaiting is a popular way of doing girls hair. I'm going to show you how to make a tiny plait on the side of the head with beads at the bottom.
You will need:
•Hair
•plastic beads with large holes
•small elastic band
You will need:
•Hair
•small elastic band
STEP 1:
Take a small chunk of hair from the side of the head around one inch wide. Make sure it's close near the top and middle of the head.
STEP 2:
Now start plaiting. Split the chunk of hair into three equal sections. Bring a side section into the middle, then the other side section into the middle. Keep repeating this until you are about two inches from the end. Use the diagram to help you
STEP 3:
It should look something like this. Remember to keep tight hold of the end.
STEP 4:
Select up to three plastic beads with large holes. Wet the end of the plait with some water and thread the beads on.
STEP 5:
Tie the bottom with an elastic band. I prefer to use a coloured one, but you can use any type, so long as it's small!
Danger is my middle name 9 years ago
Pretty! I like the colors you picked and they match your wall! :)
