Introduction: Planter Box From Pallets
This is my first project on Instructables and also my first time working with pallets. These planters are meant to house two large pots in a more attractive manner. To me, working with pallets takes a good amount of work but I do like the feeling of up-cycling something that would have gone to the landfill.
Drawing File – Plan 1
https://drive.google.com/file/d/0B21TbB8gGNQbMEl2...
Drawing File – Plan 2
https://drive.google.com/file/d/0B21TbB8gGNQbUWUw...
Step 1: Pallets
Find free pallets from Craigslist. If not available, you can purchase them locally for very little money. When searching through the pallet stack, look for the pallets with the most usable wood. The length of the slats is ~ 3 feet. The thickness varies from ½ to ¾ thick. The width of the slats can vary from 2.5 to 6 inches.
Step 2: Deconstruction
Breaking the pallets apart takes a decent amount of work. Use a jig or circular saw to cut the ends. Pry the wood from the center support. This should give you 8 to 14 boards per pallet. Remove nails from slats.
Step 3: What's Left?
Before you start cutting, determine the best pieces to get the desired width (see drawing). I had multiple long pieces with cracks and/or damage down one side. I was able to cut the damage off and still have usable pieces.
Step 4: Cut/Sand Boards
Refer to the drawings in the intro for the length of each board. After cutting the pieces, sand them with course sandpaper to remove rough spots or major staining/paint…unless that is your desired look.
Step 5: Frame
Assemble top frame (nail & glue)
Step 6: Platform
Assemble bottom platform (nail & glue).
Step 7: Ready to Build
Ready for next step
Step 8: Side Attachment
Attach the sides to the top frame and bottom platform (nail & glue).
Step 9: Trim
Attach the side trim to the upper sides (nail & glue). Attach the top trim (nail & glue).
Step 10: Clean Up
Sand again
Step 11: Stain or Paint
Finish as desired. Version shown is finished with red oak stain and coated with an outdoor urethane.
Step 12: Finished
Finished project - project done in the winter (no plants yet)!
Step 13: Updated With Plants
Step 14: UPDATE
Upgrade to the design
10 Comments
4 years ago
Lovely!! Thanks for the inspiration. I'm going to have a crack at this.
Reply 4 years ago
Thank you.
5 years ago
Looks great! Did you fill the planters direct with soil or do they have pots inside them?
Reply 5 years ago
Thanks. There are large pots inside the boxes.
7 years ago
Nice planter box. You make it look so easy in your video. Thanks for sharing your plans!
Thanks. I'm glad it looked easy but it really took more time than I would like to admit. I was SO tempted to go buy clean/straight wood from Home Depot after getting whacked in the head from a flying pallet board. Note that the second set of plans is for the person that would like to build the project from purchased wood.
Well it turned out really nice. I might try the plans for straight boards then. Thanks!
Very well done!
Me ha gustado mucho. Una explicación sencilla pero muy fácil de entender.
I liked it. A simple but very easy to understand explanation.
7 years ago
Welcome to Instructables! This is your first in a series of comments. This would be a great way to fortify my garden space.
