Planter Which Plants Other Plants
Intro: Planter Which Plants Other Plants
It is a planter which plants other plants. It has a seed dispenser, automatic plant watering bottle and a small plough. It is mainly used in small gardens where it ploughs , plant seeds and waters the plants. The planter is made of pringles can. You can make it by following these simple 10 steps
STEP 1: Materials Required
STEP 2: Attach the Motors to the Chassis
Attach the motors to the chassis by putting it in the holes and tightening the gear .Then attach the wheels by screwing them onto the motors.
STEP 3: Wiring
Connect both the positive wires of rear motors. Connect the negative wires of the rear motors to the positive wires of the front motors. Connect the right front motor's negative wire to the battery's positive wire (two 9 volts batteries connected in series or parallel). The left front motor's negative wire is connected to a switch and to the negative wire of the battery.
STEP 4: Sticking the Cap Holder
Cut the cap holder with a PVC cutter and smooth it with a sand paper. Then use Araldite to stick it down the chassis base. Then use M-Seal to secure it in place.
STEP 5: Making the Plough for the Planter
Take a metal spoon bend the end with a pair of pliers. Then attach the cap to the mouth with epoxy and again secure it with M-Seal. You can attach or unscrew by screwing and unscrewing it into the chassis.
STEP 6: Adding the Plant to the Car
Next, take the plant and stick it to the top of the batteries with hot glue gun.
STEP 7: THE SEVENTH STEP
Cut the cap holder with a PVC cutter and smooth it with a sand paper. Then use Araldite to stick it to the top end of the chassis .Then use M-Seal to secure it in place.
STEP 8: Making the Automatic Seed Dispenser
Take an eraser and cut like the picture above .Take the seed dispenser and stick the vibrator at the bottom of it.Connect the vibrator to a switch and to the AA battery holder .Then stick the eraser to the seed dispenser with hot glue .Then attach the seed dispenser to the cap with araldite and again secure with M-Seal.
STEP 9: Making the Automatic Plant Waterer
Take a bottle and cut a small hole at the side of the bottle .Then attach the cap at the bottom of the bottle with araldite and again!!!! secure with M-Seal .To fill it we should close the hole and fill water at the top.
STEP 10: Use It!
There you go! You made yourself a project which is very useful for this world environment day.
You can simply switch between the "ploughing mode","watering mode" and "seed dispenser".
ENJOY!
6 Comments
Lavanya Chittazallu 5 years ago
DIY Hacks and How Tos 5 years ago
Interesting idea. Very clever planter design.
hemeshlikeselectronics 5 years ago
Thanks a lot
AnonL 5 years ago
Dear friend,
Do you have the video to show how it work?
Thank you, friend.
Peter.
HERE'S THE VIDEO
I wil be uploading it on my youtube channel in the coming five days
